The next beta version Comfigurator 3.6.1 will have the following changes
Bugs Fixed
After scanning for Modules, the latest firmware for each module will be shown so you do not have to check for updates for every module like in 3.6.0
The Latest Version is shown next to the Current version as shown in the above screenshot. Note that the screenshot shows some \"Current\" versions as higher than \"latest\" versions (eg GSM) because of beta firmware that have been installed.
The firmware can be upgraded in the same was as in 3.6.0 ie by Right clicking and selecting \"Check for Firmware Updates\" or Firmware Upgrade from Local File\"
Known Bugs
Bugs Fixed
- Update firmware for Controller always asks to Scan for Modules
- When a new file is opened and scan for modules discovers KT03, selecting KT03 will cause an exception
- Upgrading KT03 by direct connection to PC using the KT03 USB port has an error message that UCM version 6 is required.
Known Bugs
- Trying to upgrade a module from Local File with firmware shown as \"Unknown\" after scanning will allow the firmware file to be selected. It should give an error message \"Minimum firmware is version 6 for Firmware upgrade by Bus\"
- Velbus and Zwave Configurator still has a few bugs
) so they may not need such urgently
