03-19-2013, 06:43 PM
Hi Guys,
I\'ve fixed a few bugs in the previous release version of the Comfort II Simulator. This one has a few added features and bug fixes.
I\'ve also included an updated \'Sample 1.xml\' floorplan that you can load on ComfortClient. This one has descriptions to all the objects so you can easily see which Inputs/Outputs will activate certain objects.
Just copy the \'Sample 1.xml\' floorplan over the existing one, start the Simulator in any directory and point ComfortClient to the IP where the Simulator is running.
I\'ve uploaded the Simulator to Google Drive, the link below is where you can find the Beta version.
https://docs.google.com/folder/d/0B8ULGM...sp=sharing
If you find anything that is not working as expected then please let me know and I will fix it. For new features, reply to this post or just drop me a PM and I will add it to the list for the next release.
Just a side note: If the Simulator encounters an exception it will disconnect your connected Client. If you hear the \'Exclamation\' sound, just check if the Simulator didn\'t kick you out. If so, try and recreate the problem and send me the details.
Enjoy,
Ingo
Enjoy,
Ingo
