09-07-2013, 09:20 PM
Hello,
May be more a question for cbus forums, but in wiring a bathroom for cbus lighting (light circuit star wired to node 0 and cbus switch connected only by cbus cable to cbus network), what would be the best way to trigger a traditional bathroom extractor fan in that configuration. How would you get the correct power to the fan without using a traditional switch circuit, ie a separate switch?
One idea i had was to wire the fan to a regular fuse spur and have comfort trigger an x10 microswitch on receiving the bathroom light on event from cbus, but is that the simplest/best way?
