Threads: 30
Hello,
Does anyone know of a way of using cbus PIRs instead of regular PIRs to trigger comfort alarm zones? I believe cbus PIRs only have cbus network connections and no n/c or n/o connectors.
Threads: 62
1
It\'s not a good idea, use a normal PIR to trigger Alarm functions. Don\'t daisy-chain systems for something as critical as a zone trigger. There is probably a local law that governs it as well.
Only use your Cbus PIR for \'other\' functions like turning on a light etc.
Ingo
Threads: 189
Ingo is of course quite right. This all comes down to design.
We come across homes where people have \'played around\' technically with automation.
Some can be quite good from a design install perspective but I have to say most are not good and some dangerous.
A good starting point is to look at the different areas within the home that can be hard wired - lighting heating security networks phone door entry there is more......choose the installed product.... if the product happens to be the same for heating as it is for lighting then fine.
Make sure that when you design include the overall control as a seperate heading. You may then end up with an app that does everything or seperate apps.
All of the above will then determine what you want to do totally automatically which will in turn determine where you place any logic.
First rule is that a light switch is a light switch if you disconnect the network or the heating or the app then the light switch still acts as a light switch !!!!
Sorry gone into lecture mode here !
Threads: 30
Thanks. Out of interest on the light switch is a light switch comment, when you install a cbus lighting network on a rewire, do you ever retrofit conventional (redundant) twin and earth to the switches at the same time? In the event the customer should sell up and the next buyer doesn\'t want cbus for example, he could then remove cbus components and go back to mechanical switches without putting new cables in walls. Interested in anyone\'s view of best practice here.
Threads: 189
No
Would never do this out of choice and have never been asked to do it by a customer.
IN over a decade of installing CBus (and other brands) we have never had a bus failure that has been caused by the Clipsal equipment.
