09-19-2013, 01:17 PM
New member Herold reported this problem in a different area
[color=\"#0000ff\"]\"Hi.
Module UCM PC01-066A with plugin Tibbo PC01-045B
I have got a Ethernet module which I have not used in over two years. I cant remember the IP, Tried all IP ranges I might have used since 2009 and even the 10.0.0.*.
I have upgraded my laptop since then to Windows 7 X64. I downloaded DS 5.9.10.
With no Success.
My Device reacts as follow
My D101 Red LED stays Off
D102 Green LED stays on most of the time, flash off and back on randomly.
D103 Green LED Flash twice every 2 sec about. ( This should indicate that unit was unable to establish a true network connection, and is in idle mode )
D104 Red LED stays Off.
Pressing SW101
D103 and D103 LED Start flash . ( I believe this puts module in Serial ) ?
If so, Can i use a serial cable plugged into the RJ45?
Pressing SW1
Reset Main Panel, No changes when scanning
I have used and tested Straight as well as X Cables. X over between PC and Module and Straight between Module and switch.
Switch is set up for DHCP, would have expected a result if module doesn\'t have static IP.
I was not sure if any of my Controllers PC01-051B might be to blame, Supplied 12 volts only to Ethernet module.
I have tried multiple different software programs in detecting the device, ex The Dude. with no luck.
I need to get my device to react differently on D103. Any other suggestions.?
[/color]\"
We will check your part numbers and get back to you
With no Success.
Pressing SW101
Pressing SW1
[/color]\"
