Comfigurator 3.7.6 exceptions
if when running Comfigurator 3.7.x on Windows XP exceptions like the image attached are seen, the problem could be an error in your PCs .NET Framework 2 SP
Uninstall .NET Framework 2 and re-install it again
Also  reinstall the .NET Framework 3.5 SP1 (http://www.microsoft.com/en-us/download/...aspx?id=22).
Other exceptions which are due to the.NET framework
other exception examples
On Windows 7, complete with all updates, the attached errors on attempting to close the program.
do you get this exception with a default template as well?
If it is caused by your cclx file, please send the cclx file to support@cytech.biz
This happened once with my own cclx file. It hasn\'t repeated so far. I need to see a pattern before I can take it any further. If it continues I will get back to you.
This looks to me is that Comfigurator is trying to update some variables/objects just at the point when it is closing down and disposing of those same said variables/objects.
My money would be on it being an application issue rather than anything in the config file and a timing thing so difficult to reproduce IMHO. It\'s like you exit from the application in the middle of a module scan or something.
I\'ve started to get errors trying to exit the app with 3760 that I\'ve not had with previous releases, using the same config files as before. I generate a new config for each change.
As the previous versions worked fine with the same config file, this would indicate an app error.
I can only quit by terminating the application through task manager.
As I mentioned elsewhere ( http://comfortforums.com/forum20/3544.html ), I get this error when I exit comfigurator AFTER I have performed an \"edit -> undo\" on a change I made. The only way to exit then is to start task manager and shut comfigurator down.
Please send the cclx file to support@cytech.biz so we can check the cause of  the exceptions
4 Guest(s)
