Threads: 55
I intend to add UCM/ZWave to my system and i am totally new in Z-Wave world.
As i understood from UCM/Zwave manual, i need a pripary controller to include Zwave devices into my system.
Can anyone suggest me a cheap ZWave primary controller, from that i can, then, copy the config to UCM/Zwave?
Threads: 6
You can take a remote, such as the qees for that.
Threads: 885
Does anyone have any recommendations for a good primary controller for Zwave?
We have tested some models eg ACT (not recommended), Merten, Minimote, Aeon (not good as it reqiuires software to do association), MK?
What are some other good ones?
Threads: 55
Hello Chiu,
i\'ve abandoned the Z-Wave world. I\'m stick only to UCM/KNX and Comfort shines with that. I\'ve no suggestion for ZWave, sorry.
Threads: 885
The Vera Edge has been recommended as a good Primary controller that can be used with Comfort
Threads: 262
Thanks let us know if theere are any problems with Vera Edge
Threads: 8
Hello
I have just had Comfort 2 installed with ZWave UCM. I also have the Vera Edge. How do I get Vera Edge to add device so Comfort can learn ZWave network.
Please help on which device to select to add or what option I go into on the Vera Edge screen
Bhupendra
Threads: 198
If I recall ...... the Vera edge had a list of \'Alarms\' with a pull down menu with different alarm manufacturers.....
Would it not be possible to get Comfort listed !
Threads: 885
I doubt those are actual alarm systems. do you have a list of alarm manufacturers ?
