03-02-2014, 07:49 AM
The General UCM ie UCM/ETHx, UCM/USB are used for programing Comfort via Comfigurator, and also for software applications which talk to Comfort, eg ComfortClient, Wizcomfort. It can be used with 3rd party systems that can be programmed to communicate using the Comfort Protocol and using baud rate 9600 bps, 2 start bit, 1 stop bit. This includes Crestron and other programmable systems
The Universal UCM does not use the Comfort Protocol. Instead it can be programmed to send commands to other systems using the other systems protocol.
Commands to other systems can be saved in the Universal UCM in \"Commands to Device\" and called up by Comfort Responses. Also commands from the other system can be matched and mapped to counters, sensors, zones, and responses thus giving 3 way communications.
