07-25-2014, 02:21 PM
I have a basic alarm and fire set-up with comfort but am now at the stage where I would like some
home automation. I would like to start with lighting.
I did post a while ago asking similar questions but that was for simple on-off of my exterior lights
when a PIR triggered.
This time I am looking at lights for the interior of my extension. I still donââ¬â¢t have the drywall on so a wired solution would still be easy to install.
I would like the following
LED spot lights,
Be dim-able, controlled by my phone,
Can be over-ridden by the light switch,
Can be turned on when a perimeter sensor is triggered
Expandable,
would like the solution to be cheap.
As I am not all that good at programming or using the comfort programming so the easier the better! maybe one with a dedicated UCM
Is this something I could do with products from Cytech or would zwave or Rako be better?
Thanks in advance,
Chris.
LED spot lights,
Expandable,
Thanks in advance,
Chris.
