Possible bug with Sound Types
I am trying to create a custom Sound Type, which plays a very low tone.
If I set Tone 1 Hz to 150, the sound does not play. However, if I change this to 151, it works as expected.
Is this a bug?
It may be a bug which we have to check with R&D
How low do you wish to set the frequency? 150 Hz is already quite low, near the audible frequency threshold
As low as possible. This is for a very subtle notification. 150 Hz is the lowest allowed by Comfigurator.
Not a huge problem as I can work around the issue by specifying 151 Hz, but I just thought I\'d point it out before it catches someone else out.
We can confirm that 151 Hz is actually the minimum sound frequency allowed
Currently 0 or 150 to 2400 Hz is allowed
The limit should be changed to 0 or 151 to 2400 hz
Thanks for the feedback
