Graph References
This is a feature in Comfigurator 3.9.5 which makes it easier to trace how Responses are used in Comfigurator
Right Click on any Response and select \"Graph References\"
This opens a new window which shows the connections between the Responses and what triggered it as well as what other responses are activated by it
This helps to troubleshoot and debug the programming of Comfort
Cursor over a Node to see Tooltip
Double-click Response Node to make it the Target Response.
A Response node is shown with the lamp icon. Note that only a Response can be a target
Double Click the Target Response (in blue) to Edit the Response
Select a Response from the Responses page to change the Target Response
The boxes are colour coded as follows: the Target Response is in Blue, other Responses are in Green, and other events, ie not Responses like zones, time programs, outputs etc are in White. This helps to identify other Responses which can become the new target by double-clicking on it.
Graph References works on Responses, Zones , Counters, Flags, and Alarms
