Threads: 8
Hi Chiu,I dont succeed making comfort call my cell when away mode and someone ringing at the doorphone.I tested the \"calling my cell\" function ( phone numbers initiate test). My cell gets the call.I run the \"Door chime\" response (from comfigurator). It does ring bell ok, does send the sms I added to the response. I am confused with the \"activate doorphone\" the response includes. I guess it is the function that brings the doorphone and the keyapd together. In security mode it works. In away, I cannot say. Is \"activate doorphone\" the instruction that connects the doorphone to the cellphone?I checked the above recommendations.
What else should I check to get this cellphone connected to the doorphone in away mode?Thank you
Threads: 31
I believe you have to go into Alarms, Phone numbers and make sure that the number you are using is asigned as phone. Also I cant see it on the screen shot you sent but are you working in engineering mode as the \"Alarms\" is not showing?
Threads: 8
Thanks for the tips. Yes I guess my problem came from having twice a user with same phone numbers , one vith voice, one with sms.
When I cut the call on my cell, after being in dialog with the doorphone, I hear the cell phone busy tone on the door phone. Is there a way to avoid this tone to be heard on the doorphone? The visitor can understand that there is no one at home.
Threads: 871
The problem is that it takes a few seconds to detect that the called partyu has hung up the call so the tones have to be heard.
