error reading .cctx file
I\'ve installed several versions of Configurator on a windows XP PC connected to my Comfort I system via RS232.
Selecting \'Comfort Entry\' as the profile, whenever I start the application I get the following message;
\'Error reading file C:\\Program Files\\Cytech\\Comfigurator 3\\Config\\def17.cctx - There is an error in XML document (6, 731)\'
Once I\'ve done this, I cannot change the profile to something else. Here\'s what I\'ve tried;
-Uninstalling and reinstalling (comfigurator \'remembers\' the profile and does not offer the choice again)
-Removing the \'def17.cctx\' file (configurator just replaces it on each restart)
-Renaming one of the other .cctx files as \'def17\' (same problem occurs)
-Connecting up a different PC and reinstalling (same problem occurs)
So, how do I \'reset\' configurator and get to select a different comfort profile?
Peter
I do not have this problem
which version of Comfigurator are you using?
Thanks for the reply.
As noted,I\'ve tried several versions. Specifically;
3.5.6
3.8.10
3.9.2 (beta)
The problem occurs in all versions on two different machines (both running Win XP)
I also tried with SP1a, SP2 and SP3 to no avail.
If you could advise as to where the initial profile selection is stored, that would help as I could wipe it and experiment with different profiles.
As it stands, once I make a selection on first launch and it fails, I cannot change the selection, even after an uninstall.
peter
Can you send the file C:\\Program Files\\Cytech\\Comfigurator 3\\Config\\def17.cctx so we can check if there is any problem
I\'ve attached the def17.cctx file. Note that it has not been edited by me in any way. This is from a fresh Configurator install.
Peter
.cctx   def17.cctx (Size: 112.67 KB / Downloads: 8)
I also include a screen capture of the error message. Clicking OK on this causes Configurator to disappear.
The software developer is on holiday
I believe it may be C:\\Users\\..\\AppData\\Local\\Cytech
Delete the folders names Comfigurator and  uninstall Comfigurator
[img]data:image/png;base64,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[/img]
When you install Comfigurator again uncheck Open Last File on Startup
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAa0AAAFTCAIAAAAFrMQJAAAgAElEQVR4nO2d23Mjx3noR//N5lFG6WVLcXL84GyVtXJ8UhXHhq3bipRWlmwd+WwkS+UsZK83OlUpi6zKU9ZOJdBKe+UdBAkSvGFAgMT9DpAACeJCEFfeydUu18F56Ln0zPQMQHJAApzvVygJGPT0NIaY33493f2B2tvb29vb29/f39/fPzg42Mc4ODjY29vb3d3d3t7e2trc3KzVqtVKpVJmqFQq1Uq1WqvVNjc3t7a2OXa2t3d2dtDzrU0BNQGbtVqtWq3WarVKpVqpVCqVahmjVCqXSqXixkY+n89ls2tra6urK6lkcnlpKR6Lx+PxRGJpaWlpaSmZWllJp9ey2dz6emFjo1gulysVpmHb29s7Ozs7u7t7e3sHBwcHh4dPnjz59tunT58+ffbs6OjoOeIvf/nL/xyfv5wtz58/Pzo6Ojo6evbs2bNnz54+ffrtt98eHh6iPxz6U+7u7u7u7u4cB+av1jS7QvaaZp/EgTyHx+FJE3zblqC2HR4e7u3t7ezsbG5ulsuVjY2NfD6/tra2urqaSq0kk8mlpeV4PBGJRIOhsN8f8Hp9bo/X5XIvLroWFl0ut8ft8bo9Xrfb43Qu0Hb77Oyc1Wq1WCxms3lkZGRoaGhkZMRkMpnN5rGxsfHxcYvFMjExMTExMTk5OTU1NT09PTs7O2+3LywseDwev8/n83l9Xq/P6/G43QsOh21ubspqtYyPm0dHh4eG+vv6Hj169PDBwwf3H9y7d//evfsPHjx69Kivr39gYGBwcHBocHBoaGh4eGh4aGh4aHBocHBoeHhkfNwyPT1rtzsXXR6fPxiNxZeTqfTa2lomk81mc7lcXsL6qSkosr6+Tm3Rt1+gEH//aEn8Pd/Z2UEqq9VqyIDFYrFQKBQKGxsbxWLo61cp6tVvIpx3WL3xyqsgyhXMb5VSiXFcqVQqFkvFYrFYLG5sbKA2oQ+ez+fX1wvr6+u5XC6TyayurqSSy8tLiVgsFg6HA4FAIBAIBoPBYCgUCkci0Vg8sby8nEqtpNPpTCaTy+VQK0ulUqVSqVSrtdrm1tb2zs7u3t7e/sHB4eGTb799+vQZEsvR8+cn8eDZg6zN2fDp06dPnz5FVxFuQ06IcjTpOCLNO6558Z1Ybccy3dM2A1fh4eHh3t7+zs7O1tZWpVLZ2NjI5fJra2srKyupVGp5eTmRWIrF4pFINBQK+wMBn8/v9fo8Hq/b7XG5PW63x+Px+nx+j8frXFiwYx4cHR0dHh7mPDg6OqrgQTvmQb/fH/D7gwG/3+dzu90LTqedpmdnZqyTk8iGI8PDQ0NDgwODAwMDAwNIdCbTqNlsHh8bG2cOMm4ZHx8fHxsfM49bxi1TUzM2et654PJ4fMFQOBZPJFMraSTCTBapkIjUj8dFzpL5fJ76IUX9fq5Wq9VqsQd//wfb5ubm1tYWF9xtMXGg7dYL1O9mSsVicaMQ+Ooq9YrRz6l2HTmxiLRWKgtBquNMx8oOPdbz+fV8Pp/L5bLZbCaTWVvLpNNrq6vpdDqdTq+tra1ls9l0em1lZWV5eXkpkYhGIqFg0O/zuV1ul8vlcrldLrfL5fF4fH5/IBgMRSLReDy+tLSUTCZXV9Nra5lsNpvL5/PrhY1isVQuV6vVzc3t7Z2dvb39gwNMhc+fnygiPGvwwBCPCtGFxLlGwYPHivVaocJjRX8nUGFn2RD34P4+48FqtVosllA8uLKykkyllpeXl5aWYvF4NBoNhyPBYCgQCPr9AZ/P7/X5vF6f18eIy+v1LSws0rR9ZmbWarWOj49zHhweHkYeFIWEk5OTVqsV86DT4/H4/f5AIBAKBsOhUDgUDPh9Xo/b5XI5nQ67nZ6bnZ2emrJarZOTkxMTExaLxWKZmJi0Wq1T09MzM7Nzs7Nzc3Nzc3M225xtbm5ujtlim593LC4uejy+QCAUicYSS0zskl5DKsxkScjJ8bhI5Yi2Uy9Qn0/jBqtUqtUq09nd2qptblar1Wpl9tYL1O+mixuFwvq63/gK9cp/e1G1bN189LlR2ChuYObDgk/uqLlcLpvNIfGtra2l0+n0ahr9u5dMJpeXl5eXl5PJVDK1srK6mkymlpeXE/F4LBoNh0IBn8/tdjudTofD4XA45ucddrvD4VhYQH0Dj9fv9weDoUgkEoshIaZWVlZXV9cymWwut17YKJbKlWp1c2t7Z3dv//DJk2+ZDvJRR3jwfyQqfMp68MmTJ9ydDWlIeLI+L3iw1XCtQh7c3d3d3t6u1WqlUml9fT2TyayurqLrYmlpKZFIxGLxaDQWiUTC4UgoFA6FwsFgKBgMBYLBQCAYCAR9Pt/iostun5+dnZ2cnEQeHBoaGhwcHB4eHhkZkfPg1NQU40En48FgMBgOh6KRSDQaCYdDwWDQ7/d7vR632724uOh0OObtdrvdTtO0zUbbbDRtt8/POxzOBefC4sLC4uLi4uKia3HRtbi4uLCwuOBcWFhYdLs9Pp8/EAiFw9FYPLG0tJRMpVaZ2GeNI0OCqMjjQvQjdfcqRV29G0QhXbFULJbK5ZlbbFeZujVXrc7xL69+brjKPqf+xZK1/AtF/Ysll8tZblLUzZs3mXcMk8h9ga/Y0levvkK9YvTlc9mc+79+wGz8rXl1dXVlZTWVSqWSqeRyMpFYisfj0WgsFosnEoml5WVGgolEPBaLRiOhYNDn9boWFx0Oh91ut9N2m4222Wy0zU7T8/Pz806nc3HR5fF4fD70V4xEozEUIKZSK+n0Wiaby68XNkrlam1ze2d3/4Ax4dHR0cluEZ4LonuFT1kVIqFIVdikBC+MCpU92FYqxLvGBwcHyIObm5vlcrmwsZHL5dLp9OrqamplBYUIS0tLiaWlRCIRjyfi8XgsFo/GYtFoLBKJIjP6/QGXyz0/z3hwbGzMZDINDQ0NDAyIbhGOjY1ZLBaLxSLyoJP1YCgYjETCsVgsHo/HYrFoNBIJh0OhUDAQ8Pv9Pp/P6/V6vV6Px+vxeDwer9fr8/n8/kAgEAiim1YcgUAggN4IhsLhcCQSZa7xpeVkMrWysrKyusraUCBEIkRLHgssIMtms1lqfd1/9ypFUdTn1o1CobCxEfz6VerVb8LlSqVatd16gfr9XLVambv1AvW7mXKxWCysB766Sr3y375cLpdlPJhFTzAlvvKVf319wkBRV7/yr6+vr08aKIp6xejN5yw3Kepfxpj+7yobA6aSy8mlpaV4LB6NxNBpisbiicTSMvvPYJyNB/1+v9vtdjocjnmH3W632ei5OdvcnM1mo2naTtPzDoeT+2cnGAyiu4fRWCyRWE6mVlZX19Yyufz6Rqlc2dza3t3bPzh88u3Tpx3nQaRCUVR4KBkzOZYBj+XB06jwuGMjF1iFIg9yQyWVSqVYLKKQEPWZ0PWCLplUKpVkOk+MHOPxRDQWC0eigUDQ5XLPzztmZngPDg4OIg9yXWPkQS4k5DxI0zTvwVAoGonE4/FEIoGuwXgsFovFotFoJBIJh8MhnnAoHA6HI5FINBqNRmNCogLQNlTtEhJhKpUSq7Axp7ckFyRSaDChULB+/gJ19W6gELj7KiXgh/ejKCT8/WylVCoVi6G7V6lXvvLn8/l8buImRd205HJ8YJjL5SZuUpRhcn3SQFGGyQLqLQfuXqWufuVbz+fzWctN6pX/dvN/WsFwWCwWQ2czHo8nEsvLy6nl5eTSEvp3MBGLRrn7g4sLi06H0+Fw2Gm7nbbTtN1un5+3zzudC2xIGAgEmFGUaDQWjyeWk8nUymo6ncnlC8VSpba5tbO7v394+OTbp8+Ojk44ZnxOEFX4BBswwYXVIhWe2YDJCWzYER7E24N7EN0iLJVKhUIhn88zd88zGdEFn06nV1fTaEB5eTkZTySisVgwGHK7PQ6HY3Z2dmJiAg0WIw/iXWMFD6J+cQB5MBpNxONLKBhhdIiEGOcsF2dIJJDYlpaWlgUwe6NS2E4Jdo/l5eVkMonJ8BhINEhSpIxAOR1S/AjG1OcvUJ9bA3dfpa5+E+buFKJRX9sfXqBuzdWqlUq5HPnmVerq1yFkTwNFGSbX8/nJmxR1cwLdKJw0UJTBumE1UNTnU0yHO/j1Verq3cBGoVDI59d9xldQ+MjdH+T+lonEUiwWT8TR2UmlUivsI7WSSi0vLcVjsUg4HAwE/D6/z+NFtyoWnAuLC67FBdfi4qLb7UbDJqFQGPWLo9EYO3iSWllJp9OZXH69WCpXN7d29vYPDg+/RR4kibDVU2FOg3QaDe5BUad4+5icxphEPzYvzWOFisqc0pVnCefBXfYWITc9A7+jz93wx26yr6XT6VRqZWl5ORaPh0Jhj8czP894cGxsDHmwv79/kJnJMozPnhkfH+duETIeXFjweDwoiGA8mEgsJRKJOCvBeDweYx6JOGc/9sa+BN6FTP8aBZQRFBui+W/soEAqtdIYqQ3lYka+hGhvoRCpF34/W6lUSqXS9O9eoK5+HdwIfvMqRb36TbiCTQ3cst9+gfoDjcaOY/d/SL16L1Ipl8ulmd9R1O+mihsbU59TlMFaKBQ2isWp31HU76ZL4W9epahX70XK5fLM7ymKol79JszPkilYP6cow0Q+jwZbstlsZi2DRku4fxjS6bW1TAYNqGcymcwac88Y3TGMRaORcCQUCqE5NAF/wO8P+P2BQCAYCoVRAMj985RMJlOpldXVdHotk8nm1tc3ypXq5tb23t4+mkDDjBj/5S+cCs/Pb80inUPzLTvyiK4oXIUt8mCbq1CVyLHVoGZwf7Vd9hYhujDRLIv1QkE6Gw7NKstms2trmdXV1eVkMp5IhMJhj8c77xB4cGBgQOpBs9mMPIhuETL3B2l6YWHBy3kwEonHYglGfLFYNBaNRPFHLBpjbbgkjQWTbLedvbcVi0ajkXA4FGKnvDF96Vg8Hk8I9hWYNKWIVJTcW7yIhVVzsSeyIWX7AzcI8vuZcrlUKpUj937Id4v//uHS9s7ubrLvR8wUw+3tbWbK4R/manO3KOr3s5VKZfb3aP9ymXk+W6lUqnO32M71rT/8kPrhg2itxm2iXv0mXEZaxGYO5nO5XCaTxeZUrrMzbPLov9lsdm1tLb26uoLuHC8tcxE7G52jMDvF/bORTq+l02vo5mg+v75eKBTZcZI9ZpwE92CHQZxDo0pI2KQNwYOnlyDRg9VqFYWETOjATtxFfayNjWKhsLG+Xsjl8plMNp1OJ5OpRGIpHI54vF68Xzw8PDwwMNDX18fdIuRGjTkPon7xzMwMmj/IeDAYjITDsWg0Ho0xdwSDoVAgFAwEuUcoGAqHwpFIJBqJRqPRWFTcWWb7wkwMGA6FAoEAGmPxoZk+gSAzeMKEhycnIQA7MhOCRlEzuRg0yWgiTXHXydbWFre6Y5OZRri9vbODvtPo27m3J7wBv729tbWF5hiyE6f5pSNbLNvb29v226xEd7aZaYlbaD0J6n5XKpVSqVwqMv/6sX9rNCmxjJ6US2XUh0c9BTTYk8lk1tLMzJvV1fTqymo6nc6sZTKZLNuBWM/n8+g2JVNluVyt1ra2d3b39g4OD79l5xCe3oPPzwNcgkQP4gbcagK1dNnkTcZj3WdUGGBR4PSuPAMODw+5PxnuQXa5QZG/KopFbgtSYTabRV1j3IMzMzPc/UHOg9wtQtGEatQvFnjQ70eTByPhMJo1E/AH/F6f1+31uD1ul9vtcrsX3W6328NM4fb5fX4EO2AcCoXCoRA7nBIMBgMBn8/n8XhcLtfi4qLL5XKj+d+8EwPBIJoA1BhuMDokIhjCBqn9aGgbgY6DuoyRSDQWjyeWlpLJFHVwcHBwsL/PXjDoMmC/yMy3UfpFYrXI9rx2mIttZ1t6Jezt7e05vqCoHz1OYTPa2AhlB1137ITtWrVaq1QqyIzo/mRVRKWCvhxFblZ2fl00axz9q8l+XUr8MsBqFZl6e2dnb2/vkF1Tws6kPpUIz0WCnArxrvG3woFjPBhskQeJKmyFB09mQ7Uix9YZkLus5DzI2ZBfscCrsJDN5hgPLi2FI7Ie5LrGnAfRXUI5DwYDgVAgEAoGQ4GA3+vzuNyuhcUFx4Jz3jFPz9NztG3ORs/RtI1GY5V2u33ePj8/P++YdzidzJReN7PWhcHlci0sLDjR1F+Hw+l0LiwsLLCzDXkWFtH2BeeCk3mIWFhgdkVlnE6ncwFtdLJbHMwsY8c8g90+Pz+PJhu7PV6fPxCMRKLxeIJiInPsshF+37iviCSYZ/94B5wTd4Xf4ZX+/833r//fAmNcHq403nETXZFYWMlHnciSFXa9SpGnhL4knPW4gZ5arYZqRBfo3t7ewcEB+lDP+GXGnWdADnyZ3bfY+oSThYRqRYUtUqHqIWE7ePAAC+HlPIi+7VIPohV4ch4cHh7u7+9HHsRnz3CjJZwHp6enae7+IFpU5/cH/f6A1+dxuRedTqd9np6zzU3PTlunrJbJiXHLxLjFwj0slomJycmJSesk6mXPzs3Z0EQOhwOZccHpcMzPo/nXGDRN22ibzTY3Nzc7Ozc7MzszMzM9PT09NT09NT3FPKamxczMTM+w/0WFp9AuiKmpqampKSti0jrJPKamZ2ZtNvv8vHNx0eX1+cORKPUMu3KesBNxBd+eJ+Q7KPyf8ODggL0rL/wCH7Bf2EPp95L1IB5XEua7ia40pveNPMhmfBAu56uwcR+72JlVKbpQd3f39hjBP0E94mdMOHjUuRJ8LllxTFQh+R+bVnoQVNi8B5uJB1X3IAoJuakzjAedTq/HE/D7Aj7m4fN4XAsLznkHPWebmZq2WiYt5jGzaXRkaGR4cHhocGhwYHBwYGBwYBA9hoaGTabRsbHxiYlJ69T0zMzc3JzNbrczBqQZkPjmZmdnZ2amp6as7BK98fHxsbFxs3nMPGoelX0wmEfNo6OjJpNp1GQyjZhMJtOoaVRazGQaNZlGURw8Nm6ZnLROTc/aaPviosvnD1LP2HtLgnu27F1bJj0Lj8CDgn/H0Hd5R/CtFn1bpd9m/BtPvIrwywyFhFU25w0TCW7w902QEFHeGu5mJdoLXdi77L3Og4ODwyfIg09P7MHzVp8Yae/4CXaj8LgePJkKT2NDogcVbHiRVPhEfpykJM9xPcjdIkRdY3y0BE2dQR50Op0et9vPeNDr93p9bvei0zlP03PTM1MTk+PmMdPwyNDAYP/jvscPHz188ODBvfv3v7l3/5t79+/dv3/v/oMHD/se9w8ODptM5rHxicnJqZmZWZvNhi3CYww4MzONDGixjI+PjY2Ojo6MjKDV0INIrcxjYGBgYKB/YKB/ANs4ODAwONA/0N/X3/e47/GjR48ePup73NfX19+PnI8y3wwMDnKV9A8MDAwOD4+Mjo5ZLJPWqRn7vNPl8VL4OKPUbkxYt3/AfOsODw8ODp/wljxg7i3usHlpWOOwya52d3d3OeXhX/qdnR38kuFMx90uxK9Dvk9crVa4nDfrfI4Gfmi5UEBK5JdKY9N/ttmQcH9/n4t00Rk4/f3BdoATInEajSgqVEVwTSpPwXEnVl5DqZ1AcyoMAB8Togd32HFLNHVGRBm7I9S8Bx8/foziQW72DPLg6OioyIMLjAf9bDzo9bndiw7HvI2enZ6etFjGRkeHh4YH+vofPXj44N79e19/8/VXd+8av/rK+NVXxq/u3v36m6/vPXjwqK9vYGjYZDaPT0xYp2dmbTbabp+naTsXCfJhoGV8zGweNZmGh4dR9pr+/oG+vn6lx+P+vsd9fY/7Hj96/Ojho4cPH6IMYA8fPHz48OHDh48ePep7jJzY38/W1tf3uL+vr39gYGhkZNRsHp+YtM7Z7IsuN4X/PRgD7jPDJvg1sLW9vb29g77R+/vYCtbdXTRqXKtWy+VyBfVL2YgMpf/DdMYNhnDU+P+yPVnu1h4zTsKWZ6dTFfL5XDaDT8BOocFvNDkmm2Vmx2xsbBSxr06lUqkx6SO22P7xPop3nzJJZy6OB6XrjvfPahrNKVV4rI7wCVTY0IbnpcJDbCFQizyID5WIRo3RLcLpqSmbzeZ0ONxul9/n8/t8Ab8v6Pf5vR7XgnOepudmZqwTE+Nms2l4eLB/oO/R44cPHty/d++bu19//dXdu1/dvXv367t3v/7mm3sPHz4eGBgaMZnHxyet1um5uTm7fd7hcKKuMU2jW4FCD46ODg8PDw7ykWB/P/cY4B4sgyg87O/rx1WISbC/v29gcGBoaHBoaGh4cHCIiyuHhoZNJvPYmGVy0mqj7YsuN4W+YJzUdlG/aXMTRV5MMtRyGfU3q9Xa5tYWmvvCsblZq5bLxY2NAjvDk/0/01etCEd4sQw0XMmC8B3BPKki2wUoFouFwjozRSCZXF5eQtPT0TxMtFAHzQlaWWGyEGbY/BJMtLixUSqVymX+g6CbhYeHoEI1PXgaFcp5UKEj3Oke5Gx4gN3EaOhBNLVQ5MGl43gQX2uMQsKpKavNZnM6HR63G42ThAKBUDAQ9Ps8LpfTMU/bbDPTU5OMCkeGBwcH+vv7Hj9+9PDhwwcPHj54+PDBw4cPHj1+1Ic6xeOWyamp6dlZm90+v7CwyAwWOx3z8/N2mhaq0DI2NmY2m7HbeWbuMco+2C2jJtOoacRkGjGNjIwMDw0PDQ4hJw6wQ+KCHGPmMbN5bHTUjHYxm8fGxyfQLcJ5h9Pt8VLMraBNPlIrl8vFjQ1uqjqa1ZzJZnP5fAFlreJCvmq1VquWS6WNQiGfy2Uy+AJIZuUel9SBj99WV1fY1XLsVGds+cvqaprNP8ithOYSh2UzmfTq6vLycjwWi0bCoVAw4A+w0498aEpmCM0MisUS7HIddsr56traWjabzeXX0QepVmubW9vIhoeHh0+F0wjPZplwKxAJUbTkjjMOLsRjceKbfQqOO03017C3e1zZtWYxMQGRBw/ZoRLcg9JbhHhyzxN4UNQ1NplM3CzCKRQPOp0ej9vv9wWDgVAwGA2HIqGg3+d1uxadjnmaZpIPTk5MjI+NI3WZRkZGhkdGRkaQaEZHzRaLxWqdmpm10fZ5p3PB5XKjGYJer9ftdrsWF5EOUSd5bnZ2ZmZmemraamVGda3WKe4hw/SUdWrKOmWdtE5MTFjGLWPmsTHz2PjYuGXcMsHn0Jmenp6Znp6ZmprihoynpqZnZmZn52x2u2PR5fYHgtQBEw/yISGKE7a2RBn1Ufy0g2YV7mHfV2YnSQp+fEI1PuWlyo72IpfinWDhRBd+NjYXjGzzQyXlMtsvEK41wqealssiabMjJ+iTcMEg+u6LZhGet81Ojlx4KJpxLboOVeeUjnjWNEcXBelwv+yID397np8PgC60SrVaLJUKhQKz8iqdXmFzduHL1PDVtlz2gUwmk8/lCoVCsVgsl0sVZv5ZhflBjpJg9RefT5SU5Q/lky+wA5j4pYhNd2N7gTLp9Bs9uIzSTFvyOWnmaX4NonTrxkaxVCpXKlXq3Xfefffdd995553u7u7u7u6urq5r1669+eabb7zxxmsMr7/2+uuvv/7Gm2++de3tru7ud65fv/7ee794//33P/jgg1/+8pfvv//+e++99+6773R3dXW9/fbb165du3btrbfeeuutt66xvPXWW6jO118T8Tqq/fXX33jjjTfeeONNBNr37be7urq733nnnXevX3/vvfd+8Yv337t+/Z133unq6rp27a0333zz9ddf+/nPf64X8LOf/eznqGZUG1vV211d3d2otnevX7/+3i9+8f77H/zyl7/61Yf/56OPfv3rGzdufPzxJ5988slvfvObTz/99NNPP/0MAFrPpxi/+c1vPvnkk08++eTjjz/+53/+5xs3bty4ceP/KvLrX//617/+9UcfffThhx/+6le/+uCDD37xi1+8++67XV1db731FrqKf/azn+n1+p/+9Kc//elP8euE4+c//zl7Nb7+5ptvXrt2rbu765133nkXXSrvXX/vvfeuX78uEsXb7MXOXeT4K+yKexfVw4HqYWvq7mJ5m6dLQrfk0SXaET+0sBKm/NtvdwkPwDTv+vXr1AcAAADahjIBAABoG/AgAABaBzwIAIDWEXhwYtLaS2Ji0npe7QMAAGg1Ag/29vY+OzqSPnp7e8+rfQ0wXKEoirpiOO92AADQwajlwTtdlwS/7nRGagIPAgBwalTxILLReegIPAgAwKkRe7BWq/7g2j38UatVlT2IQsFLXXcI7zGGpCiuBNpy6dIlfCOxJFev4QpFXTEII05mP/AgAACnhuBB6UPZg7IuutN1SSisS113WA923cF3JJZkPIiMiVePiRc8CADAqRF7MEeiWQ9iIdsVg+SWIdqKmYt7Si7JbOUlR4gIwYMAAJwaFTwo6heL7CbuL8t7UFxSuBV/xYWM4EEAAE6PKvMHBeMkvJqIwyckD5JLCj2I9aehXwwAgJqotZ5E1LUVRnH4VqIHiSXFUSI3koJuGYIHAQBQB1hXBwCA1gEPAgCgdcCDAABoHfAgAABa5yQeJM6tAToOk8lUBwCgXgcPahfwIAAgwIPaBTwIAAjwoHYBDwIAAjx40aENOp2BJr0DHgQAhFoepA06ipK53hpekNKaWJrZ4UzAWqVCm/ja9Ea5Amp99ON50NzNn/zLPclz+EYCwNmjkgdpg06n1ytfu817kCtGG3RypjhTjHrefka9Ki1SPhvn6cFu8zl8DwHgPFHHg+ha420hcpnOQGMhkPCVRCqC69ao5woIK2DfxWoR1SlwKFuPqBLaoNMZDHq0C74DLj5hM7BmUqKqGh6O+DH5NgiaTjpXkjaTDkpoGHgQABRRxYPspcbZg+BBfKNRz/qPEPDh+/I6EgqR1QO2K6FOfh/mmaQS2qDDTcy9L/EeY1xiJMgWbnw44sfE20A4gQ3aLDmopGEn7RdDrxjQDmp4UHDRSmIQqQdJPV8uitHp9fz9QUExHL1RdHkTe9O8obiQTbESgsCEIHtYvRIAACAASURBVB3yuhW2s+HhiCet4blSbrPooNKGnXCcxNwNJgQ0gwoeFF2qTKx2TA+SBdFMPCV9ye9IG3R6I6eIhpUwVpHVIF+ENugozDv87QDFw8l9zCbPFbnNkoOKGnZCDyZ7LoMHAa2gggcFJkMRIaYw/sLkNx6nXyzZBSvXoF/MSELPRUqSSoiWkd7MQ6rBd8F2FJlH6XDEjynnQbkPLmmz4KDShh3Lg+Zu5u5gsucy3CgENIMKHpR0LQU39/FhZNStPM44CeYlaT8U20IYJ+H3F71U7jMStSE9Nj9GIxgnVz4cYbuwn4s9J50rmTbT4n+JBA07lgeTPZfZQ4EFAe0A86iFiAaKLzQEDwKAJgEPClC+NXjBAA8CAAI8qF3AgwCAgDysAABoHYgHtYsJ4kEAqNfr0C/WMuBBAECAB7WL1IN//PLLZh7n8k0FgNYBHtQuRA/uNwI8CFw8wIPaRc6D/SMW0WPANGGyTE1Oz4EHgQuJanm3iOsmCOWOtfa2SQQrnDUzDfrUKHjQ7Y9yj0A4EU2kkivpOXqe6MHLeHIaWJcMdCAq5VkQZAyUV9FxBdckyokbABkaetAbjIWiy4nk6ko6k83lHc4Fsgcvd3dz8gMPAh2ICh4Ur0TjMxHwKbTE6UX5pa9MGZTChV8pLF5YK1pBTDoi80IpdatgA6GFkkXKtDRJqqRW5aOo5KxWoOBBbzAeiCxF4snkSjqTza0XCsVi0eP1yniwJ8nlb+U8yC9VhpXKQLujep6FHCEzFZczRdQv5spwQSSXrkaUYk9noBXSmopS1ChlMOWSlhJbKElaQ0uSpIoqaXiU5rV05sh5cHjMGk2kllPptUyuWCxWq9VarVar1SLRmKwHuUzWjAfN3RQvRjAh0Oa00oOCGE2Yn1WUvUpuew7rdUszknIHJN6eJJTH06hKo0idwSjpXxOSwUgqUT5KGyPnwfHJmZV0Jr++Xi6Xt7a2dllSK6sKHmQMiP8XvQ0iBNqelvaLT+9BYSJDuW4mIW2fQnnWUyf0oEIlpKMQG9weyHnQOmPL5ddLpVKtVtvd3d3f3z84ONjf389ks0oerNeTPZe7e8CDQOfRsnESYl+V81RzHpQm1iN7pcnUrbRBj2dqNkpbSOoXizwoqoRudBQ617bIedBmdyAJbm9v7+/vH7IUCgVlDzI/bwL9YqDTUH/ejGTAQRAWMelFRSlCyR7kf45OMtAiSWvaVOpWvkLiMIyw2cIbmvxzYSWEVkkKtCtyHnS5PZFINJlMrWUyhY2NcqVSqVYrlWqpVG7kQex3TWCcBOgcWjaPut2DoU5oYYuR8yCsJwG0BnhQuxA9COuLAQ0C6+q0i9SDAKBNIA8rAABaB+JB7WKCeBAA6vU69Iu1DHgQABDgQe0CHgQABHhQu4AHAQChSQ9qfsYM4iQehLRawEXkbPOwNs8JVCXdRZoEgbD2Wam+430obAd+qUmTn+I81Cz14GXB6SKtAwEPAheRs83D2jxqeZBYSROVH/9DGbF8E2zCrY7zYEPHgQeBi8hZ5mGVZCglZTkVVCLcILuuV7hamN9PzoyC/DTEgM+okESH3GA8EaGkyUxaQvJnZ9McovfQyuuGZ1INmvEgv0oYLRtmPchvF68mBk0CncdZ5mElpiwVZjnFHSIXH6FqpOlOj90vbi6xq/hDyTSYTSEhEBXxU/Dtx8pKU04IzpLoTKoDwYMK/WKUZ5VLL8i+a+7uNte5bNQQMAIdyRnmYTXKWEkkAuLLnFxaF2E21ob9YtyDyoldG34oOVPj7RKVx9sv93mJHpRmclSDZuJBPCCk+MSC5m5clHgZqUABoO05wzysRkVPKXsQj4mI+VCluyhsaTxaotQvJjdYvLvkdwhE7e8IDyZ7LlPCH2AShHusDSEGBDqcs8zDSkhZegwPYhpB8ZQ43SnWUyZXkhOZRamT2fhDSVvI1SXQn9jRXPsloudyLGJ3U0Ul1dRgcx7ENEhhafe7BXbks64CQCdytnlYFfqGBC8Idueym7IjCYR0p0yS15OMkxDGg8kfSjYeJNfFNUncfknbuJJcRXxJYuf91DT2IBvyURTF/DanoF/M9JXrdUn3+Yy+vQCgDhrOP9gptOxMSj0IANoEPNj2gAcBoMVocl0dkMvlwIMAwAJ5WAEA0DoQD2oXE8SDAFCv16FfrGXAgwCAAA9qF/AgACDAg9oFPAgAiM7xIEzEUZuTeBCW0AEXETXyLPCrHVopqtN4UJT06mRV8ZWouajjHJF6EPKwAtpE1Xwz0hW+KnJyD5IypJ51G9oRggchDyugSdTNuyXM6IcHiVgyUSaNn1JyVlJJQTpSPGmBaF8uuSmHJEOq3PpifneZqE+YFUapZCfQjAchDyugBVT1IB94EVOu6gw0luKeT0LTXEksAwz7VDGxK4Y4Q6o034x0d2JmF6FAlUp2AgQPKvSLIQ8rcHFR9f4gMecoF9iJ8uvJJUNVKCnqgCvsS4TLVSiXTJCUTobP/oLfWGw2EWFb00w8CHlYAS2gXjyI3xxUSImqYLfmS3IebJh4VQyWVhqP45pMs6o1D0IeVkAbqN0vZlQon3JV/KTpkqJUpmxOQuVfd2I2inrE/KGxGsGDkIcV0Coq/z4JbdDxQxaSIQg6J6O5ZkoS85wqJHblkezJFeNzuTbKCyuoprkfKml7GnsQ8rAC2qBz5lG3FOmPbmoAqQcBQJto2oNYOKg9C4IHAYBF0x7UOOBBAEBAHlYAALQOxIPaxQTxIADU63XoF2sZ8CAAIMCD2gU8CAAI8KB2AQ8CAKIFHjyzecVNHqhj5zm3mpN4EJbQARcRNTyoSpZTKaJqiQVO78GGR7m4SD0IeVgBbaKCB8VZTtXxYBPJU1XwoHopWjsQggchDyugSVTxICHLqThHqSipvWBxMSqCp0PIySRP5fKwcplZRUuZsQSFwlXDMjlTievp+GUmeoMwsaso7at0S0flZ23Gg5CHFdACKniQkOVUnKOUTwyDpYphVKbXozjMqBdGbaRq2RKoPmmgh2rFMoAZ9UyaQrmcqeKjCNKHCT+LNO2rciLYts/PSvCgQr8Y8rACFxf1xklEWU7RRrnUgaz2GE+hvYjhE7Fa5BijTMYafh+sDdLnjY8i2VegiUaJYNt+fKaZeBDysAJaQN3xYizLKdog70HaoNMbkQyZp/K9SEm1uAfxOFFc5lhukh6lkUOVt1wAD0IeVkAbqJF/kJzlFNtC6BfncrRBr+PiOb1erxc4QzZ5ai6Xw36xRJqfVWegaYMe96JR3k3So0j7xUKxSm4vyieCvRgehDysgAZQwYOyWU5zxGSrnDew+2eEW2mk5Kl4DxSrnBvX0On1nHb5PZXcREruim1D4yS0QnGFRLAXwIOQhxXQBp2znqTttdJxSD0IANoEPKhdwIMAgOgcDwJqAx4EAATkYQUAQOtAPKhdTBAPAkC9Xod+sZYBDwIAAjyoXcCDAIAAD2oX8CAAIM7Dg2czA4adTN3mSV/OEfAgACDUWFcnyDTQxPV3Gg8KUxsoLkk+nWvFa6LxNX2EPGN0rvNmOEo9SAmBhSGARlDDg8ddSXZKDzZzOOEq4RPB+4426HQ6HfZC/qAd7sF6HRJnAVpEVQ+y6iDluhcnN6WZbaQ8CNKUqxyibAt88gb8cPyxKDYnoGhVslJqVRYuIaJRz2bG4bbilWAJGgSLmmWqbR8aezDZc/lyT083JU4qwz2H9KvAhUDdfrHkmufTrUqSuHDbiHm6RClXc9i+4sNJ06PidUpS3TRIrZrDD8UkeNAbaNaK2AeixBGi4KCy1bYPTXmQSyRD8CCkXwUuCK3pFytkYeHflc+TKk01SGP7EqSJI8n7L0p9qJxaFf9gggSxwmyxcjl1pB9f+TbmudJkPCj7HNKvAhcFVT3IpTIVJUYlJTc14j9McjIPEjOnioo19KBSsGbUU3yCWNqgN9Bs97ihB9s1BsRRwYMQAwIXArXvDxITo8okN2UMh73JJVIV15kT74u9JU2P2qhfrJRaVYBRr9NxpfEXsjkWUWUNqm0Tju1BrItMsVkIIQgELgDq3h/kf6GI6RMziVHlkpuigRK+a8uUl6Zc5SC+RUyPSuj8Srq0xH1FRxPWQxg1xp6jDy4cJ2nfkZLjeRAbFGFystYh/SpwQWjL9SQd0q/sdMgeBADtAR7ULuBBAEC0pQeBMwE8CAAIyMMKAIDWAQ8CAKB1wIMAAGgd8CAAAFpH4MGJSWsviYlJ63m1DwAAoNUIPNjb2/vs6Ej66O3tPa/2AQAAtBo1PGi4QlEUdcUg/4rlisF0p+sSRVEUdanrjmB3bIOwXmzfM0LwCVB7pY0DAODC0FIPoqdChzBeuXSJ2Xyn69KlSwTVkPY9I4SfBwCAi47Yg7Va9QfX7uGPWq16Mg+SIyl2a9cV6orBZLrTdelKl7SgXBTGRpOYIxlhXrqEbyVuNAlDTJmNXaIoFPt0zR4dAICOguBB6eNkHiSHVZzhDFeQZK4YCNIj7ysJNa8YBIFjg413ui4J/XWp644w7rzTdYXbpPR5GhwIAICOQuxB4gKslniQ11KzHhRsbEZPwo14NEeK9hp8nmMcHQCAjqKFHlTuFyt3gon7quJBpToVPw94EAAuKqrMH8QNIH1OHCdpUnrCjU0rT2kjUXqn7BeDBwGgk1FrPQlxAEK0XS4qkxsUIcybkR2paFJPwr6xoAZsE1aquXES8CAAdDKwrg4AAK0DHgQAQOuABwEA0DrgQQAAtA7k5dcuJsjLDwD1eh1+n0TLgAcBAAEe1C7gQQBAgAe1C3gQABAX14NGPZrwrDeed0vaFfAgACBU8KDgN9fxn2BnTcTYiDbohFoy6ilKtC+l6K5j/L67UU/BT8E3QOrBy5d7ktyLZA/zMtlzmf0zXu5J4i8piuo2n+n3FQBaQas8SBt0uM6Mer2RNuh0ej1XmjbodDqx15RN17wHaYMOAsFGNOdBczfFbTV3d5t5P9brgucA0LG0yIMkY9EGnc5gZN8w6im9QVKK24826HQGgx6PD/lwkTkC9gorrzfigajOYOQKUoRIVW8UV6wdmvagMObD3Sd5EwA6kdZ4kBiOMY4z6ikUGxpoqS1xD3LxJNfH5csb9Vz9/BGxQxIjR2YnUeMkVTVpkc6nOQ/Wzd3CDrCgXwzRIHARaJkHpUJhN6JgjDGSYjxIy23kIzg2qhNVJdodCw/FbZNWdQKjdCZNepAB6RD6xcBFpEX9YtIwhcBibE/3xB5UvrEoOBZ+R5LkQS3FgDjH82C9znSDBduhYwxcBFTwIK48XHGkcZJGoyINPcjUadSLIjcFD2Ia5O4sikatNRQEYkg9iA2J1JM9l5noD+8RX+5Jiu4PQjwIdD5qzB8UdTxJm5l5Mw2DOGI/F3uO+tTCcRKZ3q5wF4qi+MFqbF/hOIm2RkqkHhTc+2MEJ9kkuD8IwSBwEbi486iBRhA8CACaBDyoXcCDAIAAD2oX8CAAICAPKwAAWgfiQe1igngQAOr1OvSLtQx4EAAQ4EHtAh4EAAR4ULuABwEA0TYeVHd9m4ZXyzUPeBAAECqvJ2ksHzlDkdaWCNbrHctr4MEmAA8CAELd9cVG/YlX6hIWxomStoIHVQY8CAAIVTxISjWIB4h4klRBwmpxGRqvQWegudyA0lQx/Ba9XsetScYzejHbKTzfjFyrVHdMJwAeBACECh5kEhngyWUUkqRKIzVUXCZRAp87Vc6DFJfUkH2Cb+fTzDRK3ao9wIMAgFBvnIRLr6qcJJWYS1UhYQxuQHI8SEpNKM7DygWLMq3SJOBBAECoO16M5dzHNyvEcTmSuYS70AYd80smp/Rgw+yHGgM8CAAINfJRc31LPhm1fJJUiacYJSqliTbquZgR615TzXmQ3alR6lbtAR4EAIQKHiRkMVXo82I3/gTpUZXT5bN5/rmKxXtJPShNrarcE9ce4EEAQLTNPGrgzAEPAgACPKhdwIMAgAAPahfwIAAgIA8rAABaB+JBAAC0DngQAACtAx4EAEDrgAcBANA64EEAALQOeBAAAK0DHgQAQOuABwEA0DrgQQAAtA54EAAArQMeBABA64AHAQDQOuBBAAC0DngQAACtAx4EAEDrgAcBANA6kIcVAACtAx4EAEDrgAcBANA64EEAALSOwIMTk9ZeEhOT1vNqHwAAQKsReLC3t/fZ0ZH00dvbe6aNMlyhKIq6YjjLSlQ5JgAAnYhaHrzTdYnCOZVQSE5CB7jUdefklaAtLKKquOLYgQRVHLsBAAB0CKp4kBGMasFUi+JBxWpJb0KMCACaQOzBWq36g2v38EetVlX2oGygxL1huEJRVwzCkJEpL4oj0Vbkn0uXLkk3Iinhkd2lrjvEmpvzoDBGpK4Y+GLCt9jXVwzk5hGrAgCgEyB4UPpQ9qBs1MR4EPkCfx8zJ/EpIxph11SsIdajV3ABy3VqsYbitsTKEA4kqoLUAGJZCCMBoLMQe5C46KRZD2JxGfaSFwIhbsODSZFoZPREtAyh5ibiQWmIeQwPCptHrgoAgE5ABQ+K+sViLbJvSIynmgfJNYMHAQBoDlXmDwrGSeQ8iPUmyf3iBn1M+X5xF7HmJjxIlPDJPEiuCgCATkCt9SSk8Q7xAAp3fw7dMsTKcEgCKrKUROMkxJqbmjdDmu6D7Sjo6CuHq+rOHAIA4Aw573V1F3BWHvpIoEEA6BjAg2ohjlEBAOgUztuDAAAA5w14EAAArQN5+bWLyWSqAwBQr4MHtQt4EAAQ4EHtAh4EAMRpPagw9fq8Lm+gScCDAIA4rQd7e3ufk5BboncMaINOZ6BPWwsgC3gQABBqevCvvveRsgdpg46bYidWnNR6xC347iDK00HwYLLnMnOCL/ck5b81TRYDgA5BBQ9y6Vr/6nsf4albRVcdbdBh8qMN+kYKE2vOqOf3N+r1xpMLAMjlciQP9lxmvWbulldcsrliANAxqONBUepWogf1khAQmc6gpyhKb+SsJxs0GvWUUH7MLvgOlN6I1wDhohJKHsRcJyHZXDEA6BhU8CCXrvWvvvcRnrpVdNUR+rC0QUexbmOkZtSLt/AY9ZzqSAWYeBHTJXScFZF6sF43dzfV4W2yGAB0Bip4kHv+V9/7iLgdwSqJjdZ0Bhr3FHou3SK9fJEO9cacqDCK/gTRIW5NQIzUg+ZuqttcZ+7/dZvlvjRNFgOATkFNDypvF/SL5azXjAdzOaaPzBegDTrZKBKQQ+pBrJMr3+MVvAMdY+AicHbzBwXjJLLW4wdDhOMquRxt0Il6xOzumAVzObxnDSgi9WA3F94ley4zT5M9l0W9XzOpGAB0MGe6nkQ8BEKM/pi7gJROrxdGdpIBFOyWoqAXrDQ9B+CRepA0IYY0JAzzZoCLBayr0y4ED0ph7wUCwAUGPKhdmvFgsucyaBC48IAHtUtT8SAAaADIwwoAgNaBeFC7mCAeBIB6vQ79Yi0DHgQABHhQu4AHAQABHtQu4EEAQGjPg7DwjuUkHoR1dMBFRA0PitKjngpxmoRm6jxteletIvXgZcGJJ00cBA8CFxEVPNiS9KhN2+rU6V21C8GDDR0HHgQuIqp4kJAe1cAu+kXviUNG2qDT6fU6QZmcpBIaf0kuazx1elft0owH+ZXEaCkx60HxCmNYcQx0Mip4kJAelXsl1RRKk4pHccQEMQIP8iWEqWVkgrtjpnfVLAQPKvSL0UJj5EEszYy5u9uML0KGgBHoQNQbJ5FLj0oMx8SaI8d04kpyEhEKUxASKj9eWkNt0Uw8iAeEFDLg5Z4kk48ac1/DG4sA0MaoO14sSo+KaYgznVRMp/GgaN/TpnfVFo09iOce5CJBvgxrQ4gBgQ5HBQ/KpUclbmGUiJchabDZfvHp07tqmKY8iGmQjweTPd0CO2KZWQGgA1HBgzLpUXO5HP+cy5XKZFeV/MacmGbHSYRvniS9q3Zp7EH8B5m6uy+L+8XYsIio+3xG314AUIdzmkcNndM2QOpBANAm4EHtAh4EAIT21tUBLOBBAEBAHlYAALQOeBAAAK0DHgQAQOuABwEA0DoCD05MWntJTExaz6t9AAAArUbgwd7e3mdHR9JHb29vC5tguEJRFHXFYLrTdYmiqEtdd1p4MAAAADEqePAKJeFYLgMPAgBwrqgWD55cYuBBAADOFbEHa7XqD67dwx+1WvVkHkRbRAEiYaPIg6K3hRuZXbiDGa5Q1BWDamcDAAAtQvCg9HESD3J2w58qb8SqIIWG0rcvXeKqAwAAOCliDxIXYJ3Ag5jx+BfEjeR+MVaUEBEym8CAAACoQLt7ULJNNlwEAAA4GarNH1S3XyySpFh+4EEAANRDtfUk6o+TCOJG7nYgeBAAAJWBdXUAAGgd8CAAAFoHPAgAgNYBDwIAoHVUy8tPUZTCf4E2xAR5+QGgXq+r9fskFEXV6/Xbt28T/wsqbE/AgwCAUMGDnOyU/3sulzqggNSDf/zyy2YeZ/wdBYBWo5oHFZidnQUPtiFED+43AjwIXDw048ET/GKyUY8mcOuNrWnSeSPnwf4Ri+gxYJowWaYmp+fAg8CFRE0PcitBuOdoe0MP0gYdt2+rft5d5EH+kHKWM+pVbwvXhvb4GXsFD7r9Ue4RCCeiiVRyJT1HzxM9eJmiLvckmRfJnsv8CwDoDM4/HqQNOkw4tEHfGkFI1aMsI9qgUz0QbA/9cTT0oDcYC0WXE8nVlXQmm8s7nAtkD17u7ubkBx4EOpCWxIN4YFhv5EFy2MXHazoDzRjEoBeGcLJl9EZBjMm/S4sOgUVnwsrZLjHaWxQ84geiDTqdXq+j2Bd888QNwJur1+vE20Q1n0V/XMGD3mA8EFmKxJPJlXQmm1svFIrFosfrlfFgT9LcTXWb63XMg8mey8znQG8AQPty/vEgKUQy6jkJIFvRBh3nBabDqlhGWpmyB8WV49406nG1oaoELtYZaFSKfSI6ENdScb9YseYW9MtFyHlweMwaTaSWU+m1TK5YLFar1VqtVqvVItGYrAfrdcaEjAfN3RQvRjAh0OacfzzI6oYNjQTxFxsY4RbDrCdbJieIx5g6FeNBWm6j6F1iY+Se4A2Qlmmy5pYh58HxyZmVdCa/vl4ul7e2tnZZUiurCh5kDIj/F70NIgTanvOPBwVhj1QQ+PZjleGqbVi+FR6UNoBYpi09aJ2x5fLrpVKpVqvt7u7u7+8fHBzs7+9nslklD9bryZ7L3T3gQaDzOP94UDBOIukw5gTbj1sGq//EHiT2XpvxoKgB/P6K/eI28KDN7kAS3N7e3t/fP2QpFArKHqzXzd0UGjyGfjHQSZx/PJgjzptR6NXKdTyF4uBGOphBCYV5Mw08SB7NkC3PPhE3AGuV8jiJuOaWIedBl9sTiUSTydRaJlPY2ChXKpVqtVKplkrlRh6s183dFIyTAJ1GW3gQOBfkPAjrSQCtoY4HZxsBHmxDiB6E9cWABlEt34wyZ3+RAw2RehAAtAnkYQUAQOuomYcV4r7OwgTxIADU63W1+sW5XI4yoJkyYMOOATwIAAhVPYgeYMMOQepBGCcBtImaHqzXqToFNuwYiB6EeTOABlE5HkQeNLTahnJzjFs997j1c5vPEjkPQh5WQGuo58F6narXkf4MjP0wG8r/SomOEqyP4/K2KNE+HpRk12qwF3G9yjmh4EHIwwpoCrXvD7LuE3SQDdTs7Ozt27eJO+rwdWe0QafTNRZEu3gQz41l1MvlCzzb1XLN09CDkIcV0AhqjxdTFGWg6mxgyPSQG3jQYGTlYNRTeoN0+TCWZ5CbmU1cdExYeixZryzUkDieo5UTvop2x3IgEmqUNsUoTsXa3OHkGn9KFDwIeVgBTaG2Bw0UZaBu377N/Jhncx5kkqoKXCbJxYInmCHmrRLsK03RyqU3lQnbuHSthISvwuMKd8JFTcggm1PsFzdzuGYafyLkPAh5WAGtoeo8aoPAg8yWpjzICIVJqN9kbj65LXg8xdTKVy+m+RgzJ9+r5aonHLqRBxsfTr7xp0POg5CHFdAaKq8n4e4JHteD4tx8p/Qguf8oEQqe+/AYYiKChbSid47lQfyWo6A29W0o50HIwwpoDdU8mMOzLRiwMROq4TgJMT0qsV+M3ewTdhj5LaKuJVunXmA70bGkNYhaIjwu3lTuMHKHxj6A4LlS9CdWM7nxp0bOg5CHFdAaanqQo16nZmdnmx4vlk8TLRw/4FKbciPMXBFxslXxUAP/+3Oioymla+WeS46LtZUSV0zaxqRfxSpr5nANG39K5DwIeVgBrdESD+ZyOYqicBsqeBCQhTQcrSJyHoT1JIDWoD4AAADQNtQ2AACAtgEPAgCgdcCDAABoHfAgAABaBzwIAIDWAQ8CAKB1wIMAAGgd8CDQLP81HfnHLydevjmk8cc/fjnxX9ORVpzhnp6ejz/++EPN8/HHH/f09LTiDMsBHgSa4j+t4b/5d9v33TtXEkcaf3zfvfM3/277T2tY3TP8r1980dvbWywWn2ueYrHY29v7r198oe4ZVgA8CDTFP/zR8n3PznsrT3c1z3srT7/v2fmHP1rUPcM3btwol8vPnj077893/jx79qxcLt+4cUPdM6wAeBBoipdvDl2JH533BdIuXIkfvXxzSN0z/OGHHz5//vy8P1m78Pz58w8//FDdM6wAeBBoCuTBHWBnZ2dnp0UePDqCM8xwdHQEHgTaDuTB825Fu9A6D6pbZ+cCHgTakZdvDv1d7NnWGfPwDTb14ku3fexG3+2X+Fe+2y8J3jwb/i72rEUebEVrfbdf4hJavvFQ1XpbdubBg0A7gjxYO0sevE5Rrz9Azz1/eIl66Q8e9jn7FC9ylrTIg8+eqX+G8TOn8gnD/hCq8+zZM/Ag0Ha8fHPo+7Gn1bPDdeull265sA33X6Neu4+/47r1EiUscmZ8P/a0RR5Uu6WS09ghdYMHgXbk5ZtD348+rZwZKivWYQAAArZJREFUi7deol67T9yyeOull24t3n+NEhU4Q74fbZUHVW4oOleSzfdf43/64bX7TLFbr2FbhKWYLYu32A72S7cWZStXBfAg0I68fHPoe8GDlTNj+rff+c5vpwWb/vwT6id/Rm+x1+dP/nx2LcL5XvCgFR48PDxUuaGE00gqMP3b73Ank9ll+rff4U7vn39CoUJsXdxeypWfgsPDQ/Ag0HacgwdFluO2TP/2O9R3fjvNXp5n1yaejvcg9m+JSHGyjsN3Qbv9GTwIaIyXbw79r8B+8uywfvbii59ZsQ1/+ifqn/4kfMf62YuUsNAZ8b8C+y3yoNotlZzGZDKZ/NM/cacNvY+Xkm7htjN/AMW6VQI8CLQjyIPLZ8mffkxRP/4Tej752YvUi59Nss/Zp4LtZ0jrPKh6U4VnCJ3TP/2YO7F/+jH14meTolP64meTy5OfvSgtxG5BT/G91AY8CLQjL98c+tvAXuKM+Y8fs72wFz+1sBstn74ofEVRP/6Ps23X3wb2WuHBg4ODVrTW8umLXG8WnSl8C/Xipxb8lPLP+bPPnl9uy4ufWsR/CHU5ODgADwJtx8s3h/7WvxcDYrFYLPa3/lZ58Lw/WbsAHgTakZdvDv2NbzcCRCKRSORvfLut8OD+/v55f7J2YX9/HzwItB3IgyEgFAqFQq3z4Hl/snYBPAi0Iy/fHPqudycIBIPBYPC73p1WeHBvb++8P1m7sLe3Bx4E2o5/+KPlu3RJ7y37NY/eW/4uXWpFHtZsNlutVs/7850/1Wo1m81CHlag7fhPa/jl3tm/tpf+2rut9Ye99HLvrOp5+b/44osvv/wyn8/vaZ58Pv/ll19+AXn5gTbkzmToR/82fu4/k3Tujx/92/idyVArzvDt27dv3Lih/u8edRo3bty4fft2K86wHOBBAAC0zv8HG3mH0/SkKswAAAAASUVORK5CYII=[/img]
So, in my case the config files are located here;
C:\\Documents and Settings\\<username>\\Local Settings\\Application Data\\Cytech\\
Removing the files there allow me start Comfigurator and select an alternative template. However, no matter which one I select, I get the same XML document error.
I tried moving one of the def files to root of my C: drive to eliminate any pathing issues but the same error occurs.
I had hoped to upgrade to Comfort II but if I can\'t get Configurator to run, that will be futile.
Any further assistance of ideas greatly appreciated.
Peter
Do you mean you have tried it on different computers all with versions of XP?
We will have to wait till our software developer comes back so that he can check the problem
I\'ve tried it as follows;
  • Toshiba Laptop with Windows XP SP2
  • Dell Desktop with Windows XP SP1a, SP2 and SP3
Happy to wait for developer to return.
Thanks for the help so far!
Peter
