I\'m working on the next major release of ComfortClient. You will be able to build Floorplans directly in the Editor and changes their look-and-feel via templates. A wizard will be available to quickly build floorplans for the new starters out there!
More on this later.
Screenshot is an alpha example of a rotated, scaled and manipulated \"T-Shape\" Room object, manipulated via the white and yellow drag handles respectively.
So question out there for you all. Can you post the most complicated room shapes you all have in your building designs as I want to make sure I can configure and manipulate these as a single entity in the new Floorplan Editor.
