Comfigurator 3.9.7 to 3.9.9
The new version fixes bugs in 3.9.5
Known Bugs
  1. Read from Comfort will cause Functions > Thermostats to fill up the unused Thermostats with sensor 0 and assign Heating and Cooling Outputs to Output 1. You will not be able to control Output 0 after reading from Comfort.  In order to free up Output 0, unasssign the outputs from each Thermostat
Bugs Fixed
  1. Cbus2 Response Wizard - Trigger Application action selector 255 is not accepted (since Comfigurator 3.8.6)
  2. Velbus action for VMB2BLE was wrong - does not support channels.
The new velbus commands for VMB1BLE and VMB2BLE require UCM/Velbus firmware 7.062  see http://www.comfortforums.com/view_topic.php?id=4085&forum_id=97
Thanks for sorting this Chiu!
My house now works again:-)
Mike
Comfigurator 3.9.7 has been released
This is a minor release which fixes some bugs s mentioned above
Comfigurator 3.9.9  has the following changes (compared to 3.9.7)
Known Bugs
  1. In UCM/Zwave, the Virtual Node Info button is missing
  2. various bugs in ucm/ehome
  3. KT03 Button programmed to activate Response does not work - it sends Keypad key command instead
  4. Read from Comfort will cause Functions > Thermostats to fill up the unused Thermostats with sensor 0 and assign Heating and Cooling Outputs to Output 1. You will not be able to control Output 0 after reading from Comfort.  In order to free up Output 0, unasssign the outputs from each Thermostat
Bugs Fixed
  1. When attempting to upgrade Comfort version 6 firmware via UCM and Comfigurator, error message \"Module, Comfort & UCM version must be at least 7 to upgrade this module\'s firmware by bus. Please upgrade using the UCM programming cable.\" It should be possible to upgrade Comfort firmware version 6  to version 7 using UCM firmware version 6
Improvements
  1. When KT03 landscape is changed to Portrait, a pop up message warning that the screen orientation has changed, and any screen elements which are outside the screen boundaries will be moved so they are visible.
  2. UCM/Universal allows baud rate 57600 bps. This requires Universal 7.065 firmware
New Features
  1. Support for new UCM/e-Homegreen interface see http://www.comfortforums.com/forum47/4110.html
Please take note of a bug just discovered in Comfigurator 3.9.9
This bug will appear if you use Comfigurator 3.9.9 to do write to Comfort
Please downgrade to 3.9.7 if you are using KT03 and have buttons programmed for Responses
Download link for 3.9.7 https://www.cytech.biz/download_files.php?item_id=725
Do a write to KT03 using Comfigurator 3.9.7 to fix the problem
Another workaround, which is actually a better solution is
Instead of using Button mapped to Response, select Increment Counter or Decement Counter instead of Response and a counter number
This will update the counter when the button is pressed and will trigger a counter Response. The Counter Response will do the action required. The advantage of this method is that the KT03 is not dependent on any Response number, so that you do not need to write to KT03 when you change a Response number in Comfort. Even if the Counter Response changes, the KT03 will always control the same counter which is set by the KT03 Button mapping
Comfigurator 3.9.9 is needed, and KT03 firmware 7.064 is needed
