01-28-2015, 01:56 PM
Hi All
Currently I am learning Comfort Client, I find it is a very user-friendly software. For a beginner, it does not take a long time to be familiar with everything.
But I have 2 doubts, firstly, when I select \"Click Response\" of object, in \"Click Response Type\",I select \"Comfort\" and in \"Comfort Response\" , I select the response I want to execute. Furthermore, for \"Click Response Set\" , the setting is \"Set(Off), Enabled(True)\".
It seems that when I click the icon, the corresponding response will be executed.
But only when I select the response of Control Menu in \"Comfort Response\", the response will be executed, if I select other response in \"Comfort Response\", I click the icon, the response will NOT be executed. This is a BUG or somewhere I did wrongly.
Secondly, same in \"Click Response\" section, I can see there is a \"Click Response Set\". For the \"Set\" setting, when the setting is ON, you can click the icon to execute the response as many times as you like. But when the setting is OFF, it allows you to click the icon 1 time only. e.g. My response is to toggle the light. when the setting is ON, I can click as many times as I like, the response works fine. But when the setting is OFF, I can click the icon 1 time only to turn on the light. If I click more, it has no response. What is purpose of this?
I am using the Comfort Client 4.1.7.5 now.
Martin
Martin
