Bug in X10 Received Response for All Lights On and All Units Off
We confirm there is a bug in the X10 Received Responses for All Lights On and All Units off for all addresses from A to P
The responses for all on and all off are actually reversed. All on will trigger Response for All off and vice versa
This bug was actually in the firmware since the beginning of the implementation of X10 received responses
Thanks to Mikeinnc for finding this
It should be fixed in the next version of Comfort firmware
ULT 7.074 Beta  should fix the bug for X10 received codes described above
Please download from
https://www.cytech.biz/product_details.php?item_id=210
Note that there is a slight anomaly which exists in even the older firmware
[color=\"#5500ff\"]X10 Received Responses does not start to work after a reset or power on until an X10 command has first been sent from Comfort. Sending the 1st X10 command enables the X10 interface to avoid any spurious noise from being received
[/color]
Note The above statement is untrue - please disregard it. X10 Received Response will work even without first sending an X10 command
