New Comfort Actions for KT03 Buttons
From KT03 firmware 7.070 and Comfigurator 3.10.4, KT03 Buttons can now be assigned to many Comfort Action Types, as shown below
This means that when the button is pressed, one of the Comfort action types can be triggered. These are listed below
None
No action
Response
The button will trigger the Response number. Note that If the Response number changes due to changing one of the lower numbered Responses, this will cause a change in the Response Number, resulting in the KT03 pointing to the wrong Response. To fix this, a Write to KT03 is required when the Responses have been changed. Hence it is preferable to assign to one of the other new Action Types which are not affected by changes in Response Numbers.
Key
The KT03 button causes the assigned Keypad key to be pressed. This allows KT03 to simulate a regular keypad
Increment Counter
Pressing this button causes the selected Counter to be incremented by 1
Decrement Counter
Pressing this button causes the selected Counter to be decremented by 1
Toggle Counter
Pressing this button causes the selected Counter to be toggled. This means that if the Counter value is 0, it is changed to 255, and  if the counter value is > 0, iee 1 to 255, it is changed to 0. This is useful when a counter is mapped to an external device eg KNX, CBUS or ZWave
Output On/ Output Off/ Output Toggle
Output On causes the selected Output to turn On
Output Off causes the selected Output to Turn off
Output Toggle causes the selected Output to Toggle
Flag On
/ Flag Off/ Flag Toggle
Flag On causes the selected Flag to turn on
Flag Off causes the selected Flag to turn off
Flag Toggle causes the selected Flag to toggle
