Comfort Firmware 7.077 has a new Divide Action. This also requires Comfigurator 3.10.4
Select the new Arithmetic Category (If you cannot see it there, look in Miscellaneous), Select Divide
This divides the last action value (the value returned by the last action, eg Counter 002) with either an immediate value ie a constant, a Counter, or a sensor
The result is the last action value and can be stored in a counter or sensor
eg
Get Counter002
Divide Immediate100
Set Counter002
This divides the value in Counter002 with 100 and saves the result in Counter002
eg
Get Counter002
Divide Immediate100
Set Counter002
