06-29-2015, 12:12 PM
Continuing my theme of doing short dev sprints after the last mammoth one of the base v5, this maintenance release fixes some issues found and improves existing functionality.
Also did some more verification with Windows 10 RC.
Bug Fixes/Changes
÷ Fix incorrect decode text in logfile for RD and WD/WE commands.
÷ Protect against rogue data packets being sent to ComfortClient from the UCM that are not parsable to the correct ie <STX>data<CR>. Noticed when for example Bus Monitor does not stop correctly in Comfigurator and ComfortClient is connected but not signed in.
÷ Activity Level Bulk Action in Floorplan Editor is simplified and scope widened to encompass new object types (ie plugins) and states now available.
÷ Flag, Zone, Output, X10 & CounterFlag did not display the value on objects of type Label; instead the static text value was used. Historically by-design; this is now incorrect given the increased flexibility in the configuration and usage of label objects.
÷ Refactoring and improvements to the network input buffer parsing algorithm.
÷ In Floorplan Editor the last entry in the ValueFormat dropdown was duplicated. Change \"{Prf}OFF -- {Prf}RAMP -- {Prf}ON\" to \"{Prf}OFF -- {Prf}ON\" (for duplicate).
÷ Flag, Zone, Output, X10 & CounterFlag objects now support ValueFormat.
÷ Improvements to the logfile cleanup check.
÷ Other, general, low risk refactorings.
÷ Help file updated to reflect changes.
Bug Fixes/Changes
