07-05-2015, 03:21 AM
This is a maintenances release to address a couple of issues and make some improvements. If you are using v5.x.x.x then I would encourage you to upgrade.
Quote:Bug Fixes/Changes
÷ ClickResponses do not action at runtime for Shape objects.
÷ The decode value for CounterFlags (to value 0 or 1) would affect other Counter objects with the same Object ID.
÷ In Floorplan Editor the RotateHandle is now not considered when initially selecting the object. Also when an object is selected the Rotate Handle is now moved closer to the object boundary to improve selection when objects are placed very close together.
÷ Improvements to the validation configuration logic for ClickResponses in Floorplan Editor. ClickResponses cannot be enabled unless they are validated successfully.
÷ For image objects (on/off images) linked to CounterFlags with state set to on/off would not toggle the image correctly at runtime; ââ¬ÅONââ¬Â was incorrectly determined as 255 instead of any value > 0.
÷ Fix trailing carriage return on each decoded response inadvertently added in new buffer parsing logic in the last release and that skewed the log file formatting.
÷ Monitor filters did not always work correctly if no filter checkboxes were checked.
÷ Screen does not update if ClickResponse is used without a tooltip.
