01-15-2007, 09:00 AM
It happened yesterday - armed the system to night mode, which allows us to move around upstairs, lights come on, etc.
Except tonight the alarm went off. Seems KeyPad 2 armed the system to Away mode. Except I have only 1 keypad.
The only change on the hardware is to plug an extra UCM into the COM port of the homeseer machine - but nothing configured to use it - the plugin to comfort still uses the network ucm. Only other change on the programming is changing the light sensor logic (as the sensor was going a bit bad going on and off for a bit until totally dark).
And earlier that morning I had added the 5.72 firmware
I\'ve checked all the arm repsonses i think are in there and their dependancies but cant see anything new that would force the system to arm.
In the end, I just had to power down the system for the night.
Before i did this, I loaded wizcomfort onto that new local com port to the extra UCM. This is a UCM I got from Andrew that I sent back to him originally because i couldnt get it working - but only now due to being rather busy on other things have tried to use.
This is the log from WizComfort when it decided to arm itself. Note : it also armed to away mode in the middle of me looking at the homeseer log and it was in security off mode.
So, why and how is the system arming itself !
1/14/2007 11:06:54 PM - TO: I?01
1/14/2007 11:06:54 PM - I?0100
1/14/2007 11:06:54 PM - ER00
1/14/2007 11:06:54 PM - EX0204
1/14/2007 11:06:54 PM - PS00
1/14/2007 11:06:54 PM - MD0201
1/14/2007 11:06:54 PM - AM0901
1/14/2007 11:06:54 PM - KL01000000
1/14/2007 11:06:54 PM - AL130000BF0201
1/14/2007 11:06:54 PM - OP0601
1/14/2007 11:06:54 PM - SM000040
1/14/2007 11:06:54 PM - SM000140
1/14/2007 11:06:54 PM - DT20070114230000
1/14/2007 11:06:54 PM - SM000000
1/14/2007 11:07:09 PM - TO: I?01
1/14/2007 11:07:09 PM - I?0100
1/14/2007 11:08:09 PM - TO: I?01
1/14/2007 11:08:09 PM - I?0100
1/14/2007 11:09:09 PM - TO: I?01
1/14/2007 11:09:09 PM - I?0100
1/14/2007 11:10:09 PM - TO: I?01
1/14/2007 11:10:09 PM - I?0100
1/14/2007 11:11:09 PM - TO: I?01
1/14/2007 11:11:09 PM - I?0100
1/14/2007 11:12:09 PM - TO: I?01
1/14/2007 11:12:09 PM - I?0100
1/14/2007 11:13:09 PM - TO: I?01
1/14/2007 11:13:09 PM - I?0100
1/14/2007 11:14:09 PM - TO: I?01
1/14/2007 11:14:09 PM - I?0100
1/14/2007 11:15:09 PM - TO: I?01
1/14/2007 11:15:09 PM - I?0100
1/14/2007 11:16:09 PM - TO: I?01
1/14/2007 11:16:09 PM - I?0100
1/14/2007 11:17:09 PM - TO: I?01
1/14/2007 11:17:10 PM - I?0100
1/14/2007 11:18:10 PM - TO: I?01
1/14/2007 11:18:10 PM - I?0100
1/14/2007 11:19:10 PM - TO: I?01
1/14/2007 11:19:10 PM - I?0100
1/14/2007 11:20:10 PM - TO: I?01
1/14/2007 11:20:10 PM - I?0100
1/14/2007 11:21:10 PM - TO: I?01
1/14/2007 11:21:10 PM - I?0100
1/14/2007 11:22:10 PM - TO: I?01
1/14/2007 11:22:10 PM - I?0100
1/14/2007 11:23:10 PM - TO: I?01
1/14/2007 11:23:10 PM - I?0100
1/14/2007 11:24:10 PM - TO: I?01
1/14/2007 11:24:10 PM - I?0100
1/14/2007 11:25:10 PM - TO: I?01
1/14/2007 11:25:10 PM - I?0100
1/14/2007 11:26:10 PM - TO: I?01
1/14/2007 11:26:10 PM - I?0100
1/14/2007 11:27:10 PM - TO: I?01
1/14/2007 11:27:10 PM - I?0100
1/14/2007 11:28:10 PM - TO: I?01
1/14/2007 11:28:11 PM - I?0100
1/14/2007 11:29:11 PM - TO: I?01
1/14/2007 11:29:11 PM - I?0100
1/14/2007 11:30:11 PM - TO: I?01
1/14/2007 11:30:11 PM - I?0100
1/14/2007 11:30:59 PM - XTK0207
1/14/2007 11:30:59 PM - CT1C00
1/14/2007 11:31:11 PM - TO: I?01
1/14/2007 11:31:11 PM - I?0100
1/14/2007 11:32:11 PM - TO: I?01
1/14/2007 11:32:11 PM - I?0100
1/14/2007 11:33:11 PM - TO: I?01
1/14/2007 11:33:11 PM - I?0100
1/14/2007 11:34:11 PM - TO: I?01
1/14/2007 11:34:11 PM - I?0100
1/14/2007 11:35:11 PM - TO: I?01
1/14/2007 11:35:11 PM - I?0100
1/14/2007 11:36:11 PM - TO: I?01
1/14/2007 11:36:11 PM - I?0100
1/14/2007 11:37:11 PM - TO: I?01
1/14/2007 11:37:11 PM - I?0100
1/14/2007 11:37:41 PM - IP0801
1/14/2007 11:37:41 PM - CT26FF
1/14/2007 11:37:41 PM - CT0114
1/14/2007 11:37:43 PM - IP0800
1/14/2007 11:38:10 PM - IP0801
1/14/2007 11:38:11 PM - CT26FF
1/14/2007 11:38:11 PM - CT0114
1/14/2007 11:38:11 PM - TO: I?01
1/14/2007 11:38:11 PM - I?0100
1/14/2007 11:38:15 PM - IP0800
1/14/2007 11:38:16 PM - IP0801
1/14/2007 11:38:16 PM - CT26FF
1/14/2007 11:38:16 PM - CT0114
1/14/2007 11:38:18 PM - IP0800
1/14/2007 11:38:36 PM - CT0CFF
1/14/2007 11:38:38 PM - IP0801
1/14/2007 11:38:38 PM - CT26FF
1/14/2007 11:38:38 PM - CT0114
1/14/2007 11:38:40 PM - IP0800
1/14/2007 11:38:45 PM - IP0801
1/14/2007 11:38:46 PM - CT26FF
1/14/2007 11:38:46 PM - CT0114
1/14/2007 11:38:46 PM - CT0C00
1/14/2007 11:38:47 PM - IP0800
1/14/2007 11:38:50 PM - IP0801
1/14/2007 11:38:50 PM - CT26FF
1/14/2007 11:38:50 PM - CT0114
1/14/2007 11:38:57 PM - IP0800
1/14/2007 11:39:11 PM - TO: I?01
1/14/2007 11:39:12 PM - I?0100
1/14/2007 11:40:11 PM - TO: I?01
1/14/2007 11:40:12 PM - I?0100
1/14/2007 11:41:12 PM - TO: I?01
1/14/2007 11:41:12 PM - I?0100
1/14/2007 11:42:12 PM - TO: I?01
1/14/2007 11:42:12 PM - I?0100
1/14/2007 11:43:12 PM - TO: I?01
1/14/2007 11:43:12 PM - I?0100
1/14/2007 11:44:12 PM - TO: I?01
1/14/2007 11:44:12 PM - I?0100
1/14/2007 11:44:50 PM - ER00
1/14/2007 11:44:50 PM - EX0204
1/14/2007 11:44:50 PM - SM000140
1/14/2007 11:44:52 PM - SM000000
1/14/2007 11:44:54 PM - PS00
1/14/2007 11:44:54 PM - MD015B
1/14/2007 11:44:54 PM - AM095B
1/14/2007 11:44:54 PM - AL130000BF025B
1/14/2007 11:44:54 PM - OP0601
1/14/2007 11:44:54 PM - SM000140
1/14/2007 11:44:54 PM - CT1600
1/14/2007 11:44:54 PM - CT2300
1/14/2007 11:44:54 PM - CT1500
1/14/2007 11:44:54 PM - CT2800
1/14/2007 11:44:54 PM - CT1200
1/14/2007 11:44:56 PM - SM000000
1/14/2007 11:45:12 PM - TO: I?01
1/14/2007 11:45:12 PM - I?0100
1/14/2007 11:45:28 PM - SM000040
1/14/2007 11:45:31 PM - SM000040
1/14/2007 11:45:51 PM - AM0801
1/14/2007 11:45:51 PM - KL00010000
1/14/2007 11:45:51 PM - AL110000140201
1/14/2007 11:45:51 PM - MD0001
1/14/2007 11:45:51 PM - OP0600
1/14/2007 11:45:59 PM - SM000040
1/14/2007 11:45:59 PM - SM000140
1/14/2007 11:46:02 PM - SM000000
1/14/2007 11:46:12 PM - TO: I?01
1/14/2007 11:46:12 PM - I?0100
1/14/2007 11:46:18 PM - IP0801
1/14/2007 11:46:20 PM - IP0800
1/14/2007 11:47:12 PM - TO: I?01
1/14/2007 11:47:12 PM - I?0100
1/14/2007 11:48:12 PM - TO: I?01
1/14/2007 11:48:12 PM - I?0100
