01-20-2007, 09:24 AM
Details: G2 V5.05 Def 34
Doorphone G2 - i have the details of all three if required.
The current problem: when i use an internal phone to dial into comfort and talk to doorphone (6) everything works OK for between 30 sec to ........5 min (sometimes it is perfectly ok) then the doorphone gives a loud beep beep beep beep beep beep ...... you cannot get rid of this unless you clear down. The same happens of someone rings the doorphone and it is answered on the internal phone.
In order to rectify the situation i have attempted to change the doorphone, however I was on site yesterday with 2 new doorphones. They actually made the problem worse e.g. the beep beep occured EVERY time the dorphone was answered.
My only option left is to change the main board? Can someone please shed some light on this problem?
