For all those ComfortClient users out there, you\'ll notice I\'ve today advertised a new build. It\'s been a while as I\'ve stepped away from the keyboard for quite a few months to rest up from coding evenings (this isn\'t my day job!!) and to get some exercise as was getting middle-age spread if you know what I mean. Anyway...
The fixes and new features are shown below. Upgrade from within the running application or download via the links on this forum or via my website.
Enjoy
÷ Migration from Visual Studio 2013 Community Edition to 2015 Pro IDE.
÷ Switch from .NET 4.5 to .NET 4.6.1. ComfortClient, Floorplan Editor plus the Application, Email and GSM4 (standard connectors) are uplifted to .NET 4.6.1, other connectors and plugins continue to run on .NET 4.5 until their next releases respectively.
÷ General code refactoring for improved logic and performance.
÷ ComfortClient now attempts to re-logon after system or UCM reset (RS or RSXX).
÷ The UCM Type on the SS command is now decoded.
÷ Logoff with Debug Mode enabled, when no plugins are loaded, would cause an exception and ComfortClient would close.
÷ On 64bit operating systems, the 64bit version of FTD2XX.DLL would be installed even though the application is 32bit, leading to ââ¬ÅAttempting to load FTD2XX.DLLââ¬Â¦Ã¢â¬Â dialog box at start-up.
÷ Updated version of the embedded Infralution Licensing code.
÷ Improve Floorplan Tab Activity update and clear cycle. Reduce Tab flickering as much as possible.
÷ Updated Event Log decode with additional parameters now passed from Comfort.
÷ Updated decode module types in SS command to now include Types 129 and 130, IRIO and TSM extended module types respectively.
÷ ASM01 (Arduino Sensor Module by Ingo) type added to TSM decode.
÷ The ââ¬ÅIs Temperature?ââ¬Â checkbox is now unlocked for Comfort Sensor types on floorplan objects because sensors can now report more than just temperatures.
÷ Occasional \"Permission denied for user..ââ¬Â errors when closing ComfortClient when signed in.
÷ Sensor Object Types now implement the ââ¬ÅIs16Bit?ââ¬Â checkbox.
÷ Debug Monitor window now auto scrolls to last entry to keep it in focus.
÷ Sensors and Counters now decode negative values correctly.
New Features
÷ Support decode of TSM and HIO module types.
÷ Support decode of ââ¬ÅELââ¬Â, EOL Shunts, command to log file/monitor.
÷ Support decode of HIO command replies (H?) and reports (H#), command to log file/monitor.
÷ Add ââ¬ÅActivate Now!ââ¬Â button to the Time Programs Window.
÷ Add ââ¬ÅLog File Monitorââ¬Â on Information menu; shows a real-time view of the log file data written during the current ComfortClient session.
÷ Extended ValueTransform property for floorplan Label & Gauge objects, allows Comfort Sensor values too be converted relative to a ââ¬Åreference valueââ¬Â (for Analogue Input conversion).
÷ A ââ¬ÅReset Colour Paletteââ¬Â button added to the Debug Monitor window to allow the auto-selected items colours to be re-selected.[/size]
Enjoy
New Features
