Comfigurator 3.11.9 - 3.11.10
Known Issues
  1. In Flags screen, if Check Status box is checked for a flag, the status is updated, but if the flag changes subsequently, the flag status in the centre pane is not updated until you go to another page and back, or uncheck and check the box (old bug)
  2. In Modbus configurator, Sensors cannot be mapped to Modbus
  3. for TSM, if older firmware eg TSM 7.001 has read from EEPROM, this may cause  an exception. Workaround is to upgrade TSM to  the latest (7.003) firmware first
Bugs Fixed
  1. \"If Input\" comparison action did not work for Input > 64 to 96. This also applies for older versions
  2. Deg C /deg F in Comfiguration flags is incorrect
  3. Comfort Optimum when adding  UCM/KNX2 caused exception
  4. Read from KP06A or KP04A does not change the KP06A/KP04A settings  in Comfigurator
  5. IRIO IR codes do not refresh when new IR codes are learned. Refresh button is needed
  6. Default template def40.cctx for UCM/Logic is missing from the installation.
  7. Export Scenario dis not work. Selecting any items will cause an exception
New Features
TSM01
  1. Added parameters; Heating / Cooling Mode, Virtual Input, Heating/Cooling Output, Virtual Alarm Offset, Calibration Offset. This implements the Temperature Alarm Monitoring feature which maps to Virtual Input to trigget the Temperature Alarm. New Temperature Alarm Type, TempNO Zone Type added to defaults.
HIO
  1. Added Lighting Sequence Timer Parameter for delay between each light turning off in Occupancy Detection Mode
IRIO
  1. Added Resistive Sensor Input Functions
UCM/Modbus
Supports the new UCM/Modbus. New Product will be announced soon
Comfigurator 3.11.9 has been released
Please take note of the known issues in the 1st post
Receiving the following error after updating to 3.11.9:
System.NullReferenceException: Object reference not set to an instance of an object.   at Comfort.MiscellaneousEvents.get_ShowPartition()
Anyone any ideas?
Jim
can you send the cclx file to support@cytech.biz?
something in the file seems to be not compatoible with partitions
Thanks Chiu. File sent. I did try going back to 3.11.6, unchecking load last file, then re-installing 3.11.9, but no joy with that, same exception error.
Jim
we do not get the exception with your file
Does the error appear when you start comfigurator or when you load your cclx?
I get the error when starting Comfigurator. IE with an untitled cclx.
we have not been able to duplicate the exception but we believe this new beta version 3.11.10 should  fix that problem
Please upgrade from https://www.cytech.biz/product_details.php?item_id=206 and let us know the result
3.11.10 has fixed the problem. All good now, thanks
Jim
Comfigurator 3.11.10 has been released
Bug Fixes
  1. Fixes the exception \"System.NullReferenceException: Object reference not set to an instance of an object.  at Comfort.MiscellaneousEvents.get_ShowPartition()\" when starting Comfigurator. This has been reported by some users.
  2. Fixed Bug in UCM/Modbus Sensors could not be selected
  3. Fixed Links to Manuals for HIO, TSM, IRIO, Modbus. Note there is a slight bug in Link to Modbus manual. When a new Modbus is added, the link is incorrect, but after the file is saved and reopened, the manual link works
  4. New version of Bus Monitor and IR Learner are included
  5. UCM/GSM4 - Spaces are automatically added to Zone Names, Alarm Names, User Names before capital Letters in SMS eg \"FrontDoor\" becomes \"Front Door\". This is needed because Comfigurator does not allow Spaces in Names. Also the UCM/GSM4 Properties shows the GSM module name eg 800, 900 etc which will cater for new models
  6. Default Responses - Fixed Error in Vibration Responses
