Triggering external events via HTTP from ETH03
Does anyone know if there\'s a way to make the ETH03 module initiate an HTTP call?
I have a QNAP NAS with a CCTV system setup on it and currently 1 camera pointing at my front gates. My Comfort system has a wireless sensor on the gate and it currently triggers an SMS event and a voice announcement when the gate opens. The CCTV s/w on the NAS has the ability to trigger recordings based on virtual triggers that are initiated by making an HTTP request - e.g.:
http://192.168.1.123:8080/cgi-bin/logical_input.cgi?name=GateActivated
Since I have a UCM/ETH03, is there any way I can setup a Response to do that?
Thanks.
The UCM/ETH03 is not able to support an http request
Ok, thanks. I imagined that may be the outcome.
However, just in case anyone else has a similar requirement in the future... I\'ve come up with a simple(ish) plan:
I will buy a cheap generic Wifi enabled Arduino-style device (e.g. NodeMCU or WeMOS D1) from eBay and set it up to monitor a Comfort Output pin.  When the output is triggered the little microcontroller will then initiate the HTTP call.
I\'ll need to use appropriate voltage dividers to step-down power supply and ensure the voltage on the Output pin is compatible with their input, etc.
And I\'ll need to find the time to ever get around to it Smile
I think the RPi device should be able to do this, see http://www.comfortforums.com/forum136/
Try posting your question on that forum
