Bypass garage doors when using door remote opener
[size=I want to shunt my two garage doors and the garage PIR when the doors are opened with the door remote control. I have a response from a RIO input from the remote opener. However I also have the garage doors as an entry zone and when I arm the system the \"final door\" doesn\'t activate as the bypass has turned on. I can\'t seem to find the logic that will only allow the bypass when the system has armed.]
You can use the AWAY Response in Miscellaneous Events  to bypass the door after armed
Thanks, that is just the information I needed and so fast!
Have you added this to the home control manus so that it appears on the app?
You should be able to add the feedback in but go careful you need to realise how the top level menus structure works - there are in effect a lot of wasted spaces at the bottom of the tree !
