In Comfigurator 3.13.1, (requires Comfort Firmware 7.174 and above) a useful feature has been introduced - Occupancy Status
This allows Comfigurator to display the Occupancy Status is active, ie if there has been any movement in the selected zones in the premises
In the above screenshot, the occupancy status is Inactive. If there were movement detected in selected zones, the occupancy Status would be Active
This is programmed as follows;
Select the zones which will detect occupancy. These are normally Motion detectors (PIRS)
Create a Response called eg Occupancy
In the Zone On and Off Response, assign to the Response which was created (Occupancy in this example)
In Alarms Misc Settings> Occupancy Time, enter the time to detect occupancy eg 30 minutes. This means that the occupancy will be inactive if the zone does not detect movement for 30 mnutes
Assign the same Response to all the zones which will take art in Occupancy Detection
for example if 4 zones are assigned to Occupancy detection, and the occupancy time is 30 minutes, the Occupancy Status will be Inactive if zone of the zones detect occupancy within that time. If any zone detects movement in that time interval, then Occupancy is Active
