Hi Ingo, appreciate you getting back to me. Here is the log file rgds Clive
2024-10-23 00:07:11 DEBUG r?00F00F000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:27 DEBUG ER00
2024-10-23 00:08:27 INFO Ready To Arm...
2024-10-23 00:08:27 DEBUG SM000140
2024-10-23 00:08:27 DEBUG EX0205
2024-10-23 00:08:31 DEBUG PS00
2024-10-23 00:08:31 DEBUG SM000040
2024-10-23 00:08:31 DEBUG SM000140
2024-10-23 00:08:32 DEBUG MD0203
2024-10-23 00:08:32 INFO Armed Night Mode
2024-10-23 00:08:32 DEBUG AM0903
2024-10-23 00:08:32 DEBUG KL01000000
2024-10-23 00:08:32 DEBUG S?13
Traceback (most recent call last):
File \"/comfort2/comfort2.py\", line 2877, in <module>
mqttc.run()
File \"/comfort2/comfort2.py\", line 2443, in run
self.publish(ALARMSTATUSTOPIC, SMsg.modename,qos=2,retain=True) # Idle, Alert etc.
AttributeError: \'ComfortS_SecurityModeReport\' object has no attribute \'modename\'
[23:08:32] WARNING: Halt add-on with exit code 1
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun comfort2mqtt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[00:08:36] WARNING: TLS encryption option disabled.
[00:08:36] INFO: Starting Comfort to MQTT...
2024-10-23 00:08:36 DEBUG Starting new HTTP connection (1): supervisor:80
http://supervisor:80 \"GET /addons/self/info HTTP/11\" 200 9727
2024-10-23 00:08:36 INFO Importing the add-on configuration options
2024-10-23 00:08:36 INFO Completed importing addon configuration options
2024-10-23 00:08:36 DEBUG The following variable values were passed through via the Home Assistant
2024-10-23 00:08:36 DEBUG MQTT_USER = mqttbroker
2024-10-23 00:08:36 DEBUG MQTT_PASSWORD = ******
2024-10-23 00:08:36 DEBUG MQTT_SERVER = 172.30.33.9
2024-10-23 00:08:36 DEBUG MQTT_PROTOCOL = TCP/1883 (Unsecure)
2024-10-23 00:08:36 DEBUG COMFORT_ADDRESS = 192.168.1.77
2024-10-23 00:08:36 DEBUG COMFORT_PORT = 1001
2024-10-23 00:08:36 DEBUG COMFORT_LOGIN_ID = ******
2024-10-23 00:08:36 DEBUG COMFORT_CCLX_FILE = 13MeadowCt_2018_v1.3_DRdis_DSdis.cclx
2024-10-23 00:08:36 DEBUG MQTT_CA_CERT = ca.crt
2024-10-23 00:08:36 DEBUG MQTT_CLIENT_CERT = client.crt
2024-10-23 00:08:36 DEBUG MQTT_CLIENT_KEY = client.key
2024-10-23 00:08:36 DEBUG MQTT_LOG_LEVEL = DEBUG
2024-10-23 00:08:36 DEBUG COMFORT_TIME= False
2024-10-23 00:08:36 WARNING MQTT Transport Layer Security disabled.
2024-10-23 00:08:36 INFO Comfigurator (CCLX) File detected, 236514 Bytes
2024-10-23 00:08:36 INFO Connecting to Comfort (192.168.1.77) on port 1001
2024-10-23 00:08:36 INFO MQTT Broker Connection Success
2024-10-23 00:08:36 DEBUG Subscribed to 16 Zone Outputs
2024-10-23 00:08:36 DEBUG Subscribed to 32 Zone Inputs
2024-10-23 00:08:36 DEBUG Subscribed to 0 RIO Outputs
2024-10-23 00:08:36 DEBUG Subscribed to 254 Flags
2024-10-23 00:08:36 DEBUG Subscribed to 32 Sensors
2024-10-23 00:08:36 DEBUG LU03
2024-10-23 00:08:36 INFO Comfort Login Ok - User 3
2024-10-23 00:08:36 DEBUG Subscribed to 255 Counters
2024-10-23 00:08:36 DEBUG Subscribed to 0 Responses
2024-10-23 00:08:36 DEBUG Synchronizing Comfort Data...
2024-10-23 00:08:36 DEBUG Synchronization Done.
2024-10-23 00:08:41 DEBUG b?00000000000000000000000000
2024-10-23 00:08:41 DEBUG Zones Bypassed: 0
2024-10-23 00:08:41 DEBUG V?FE078C22400100
2024-10-23 00:08:42 INFO Comfort II ULTRA detected (Firmware 7.140)
2024-10-23 00:08:42 DEBUG EL1111FFFFFFFF
2024-10-23 00:08:42 DEBUG 1 Installed SEM(s) detected
2024-10-23 00:08:42 DEBUG Hardware Model CM9000-ULT
2024-10-23 00:08:43 DEBUG DL7FF9045C172F00E2
2024-10-23 00:08:43 DEBUG SN015C172F00
2024-10-23 00:08:43 INFO Refresh Key: 5C172F00
2024-10-23 00:08:43 INFO Serial Number: C086172
2024-10-23 00:08:45 DEBUG M?0203
2024-10-23 00:08:45 INFO Armed Night Mode
2024-10-23 00:08:45 DEBUG Z?00000000
2024-10-23 00:08:45 DEBUG Max. Reported Zones/Inputs: 32
2024-10-23 00:08:45 DEBUG z?000000000000000000000000000000
2024-10-23 00:08:46 DEBUG Max. Reported SCS/RIO Inputs: 120
2024-10-23 00:08:46 DEBUG Y?0E010000
2024-10-23 00:08:46 DEBUG Max. Reported Outputs: 32
2024-10-23 00:08:46 DEBUG y?000000000000000000000000000000
2024-10-23 00:08:48 DEBUG Max. Reported SCS/RIO Outputs: 120
2024-10-23 00:08:48 DEBUG f?00F9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2024-10-23 00:08:50 DEBUG S?00
2024-10-23 00:08:50 DEBUG a?130000000000000000
2024-10-23 00:08:50 DEBUG r?0100100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0110100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?000010FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0010100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0020100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0030100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:51 DEBUG r?0040100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0050100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0060100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0070100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0080100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?0090100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:52 DEBUG r?00A0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00B0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00C0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00D0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00E0100000000000000000000000000000000000000000000000000000000000000000
2024-10-23 00:08:53 DEBUG r?00F00F000000000000000000000000000000000000000000000000000000000000
