05-20-2007, 02:44 AM
can the RS232 interface on the Comfort work with Cortexa products:
http://www.cortexatechnology.com/index.php
Cortexa
05-20-2007, 03:02 AM
I have not heard much of this product so far. What did you have in mind for it when used with Comfort?
Currently Comfort UCM is able to send any arbitrary command to an external device through RS232 or Ethernet, but firmware needs to be developed to receive commands the other way. Hence we can do this for products which are widely used. Yanza is also developing the MCE plug in for Comfort, see http://www.comfortforums.com/forum27/
05-20-2007, 04:44 PM
Thanks for your reply.
I am thinking of using this for a graphical UI for Comfort. The Wallmount touchscreen is the same product as SideKick although with different firmware and cheaper.
05-23-2007, 01:40 AM
The problem is that interfacing to products like Companion will require the other manufacturer to add support for Comfort in the screen.
We are quite open as far as our communications protocol, but others may not be so. Hence your question is better directed at Cortexa if you have coontact with them |
| 1 Guest(s) |
