evaluation kit problem
I was putting together my kit, put the 12v link to the ucm put on power and realised that 12v plug was turned around the wrong way.
Is there a way of re setting a fuse on the ucm or do i have to order a new one???
Do you mean the 12 Volt removable terminal block on the UCM was reversed?
This should not damage the UCM as it is protected against this.
Or do you mean the 4 way white connector was reversed? This may cayse damage but is extermely difficult as it is keyed to accept the right orientation only
Yeah the 12 v block was reversed, all lights on ucm are off when i try to sync with laptop keeps saying no response from ucm. Is there any type of re settable fuse or anything???
No resettable fuse in this case, unfortunately. You will have to return the UCM for repair.
alright thanks!!
