[size=\"2\"]Ultra 5.121 (10 January 2008) [/size]
Firmnware Downloads apply to Comfort with Flash memory only from Firmware 5.106
Known Bugs[/size]
- [size=\"2\"]An upgrade to the latest Comfort firmware is highly recommended.
- Support for different sizes of voice recording memory for future
- Fixed bug for wrong determination of sunrise and sunset times after the daylight saving day change within the same week
- Fixed problem No Batttery detection does not work when current drawn from Comfort is low
- Fixed problem x10 receive was not working
- Baby Monitor Response works
- Keypad Menu 5 for Voice Station works with other keypads.
- Fixed BUG from 21/9/05 if arm fail due to exit timer and inactive zone (eg digital zone) is ON, event log will report the inactive zone. Now Event log will report only active zone which is still ON (open)
- Zone activation is reported to event log before Security Off and armfail alarm events, so sequence is more logical
- If arm failed due to timeout without any zone opened dont report any zone in Event Log to avoid confusion about the cause of the alarm.
- Dont report tamper as Arm Fail, zone 254 in event log as tamper will cause an immediate alarm
- EN50131 Hide alarms mode. Event Log menu will now not cut off the speaker in the middle of the menu.
- CLK pin outputs 32768 Khz signal (testing only)
- Access User Responses enabled for ENTRY version
- Added Doorphone On and OFF Responses (In File System 34, Locations 780/781, 782/783 In File System 31 Locations 1731, 1732)[/size]
Known Bugs[/size]
- [size=\"2\"]
- If Modules & Settings > Show alarms disabled, Door Station chime is not heard
- For DSP Flash, if if LCD sector not found, green led does not blink, and there is no Rs485.
- Clear Answ Machine Bypass (Program menu 1,0,0) also clears Call Screening of calls on Keypad 1
- After reset , When Doorbell is pressed, local phone cannot hear doorphone unless phone is used 1 time then OK
- When GSM is accessing comfort, local phone offhook will cause line cut detect and cut off call
- Wrong Daylight Saving Time change if last day of DST change is < 31st of month.
- GSM incoming call not answered when alarm is repeating zones continuously
- Action 88 Do alarm User is nnot recorded into event log
- LEM03 zones 17 to 24 words are not sent to KP04 Display
- Zone 64 does not work
- if AGC and Intercom tune parameter do not work
- Local phone when arming, pressing * to abort can hear user menu on KP Vmenu
- LCD text download sometimes does not work - causes Sync message again due to checksum error
- DA command to UCM does not work for SKIP action
- GSM Line IN Gain (Parameter 52) does not work
- GSM dialing to 2 phones - at 2nd phone dialout when user terminates \"goodbye\" the call may not be ended
- GSM dialout to CMS does not work in Comfort II
- Speaker screeching sound and LINE CUT false detection durng download
- UCM DA Action 200 causes reset
- Intercom performance is not optimised
[/size]
