Minderpro - Text error press *1 to syn - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Keypad (https://www.comfortforums.com/forum-69.html) +---- Thread: Minderpro - Text error press *1 to syn (/thread-1302.html) Pages:
1
- slychiu - 02-16-2009 Can you explain exactly step by step what fault you are seeing? Please start from the begining - Manas - 02-16-2009 Yup. 1. I connect all modules and start programming. \'Download complete\' indication on PC 2. When I reach kp, it shows the error, \'press *1 to synchronise\'. This error happen randomely(acc to my rough observation). 3. When I press *1, sync gets completed but error msg remains. But this time, I am able to listen to announcements.. such as \'security off\', \'night mode\', or any other alarms. 4. When I reset comfort manually, the text error is again displayed. But if I press *1 this time, sync gets completed and I get a proper disply with \'date/time and status\'. Will it help? because comfort program in both case is same. - slychiu - 02-17-2009 This happens after a full download What is the firmware of your Minder Pro? You can see this from the label on the U1 IC on Minder Pro PCB marked ULT 5.1__ or do a Transfer > System Information on Comfigurator or Mindit If your firmware is before ULT5.145 you will see this problem, see forum at http://www.comfortforums.com/forum60/1195.html Do a firmware Upgrade using the UCM05 if you have one. For Clipsal this is 5352UCM, not 5350UCM See the picture at https://www.cytech.biz/Default.aspx?cmd=ID%2ftW5Xw2bTCO626ZAAInw%3d%3d&productid=126&categoryid=9&pageindex= - Manas - 02-17-2009 You are right. The firmware version is 5.054. It\'s old. And regarding UCM05, we don\'t have its reference in our system in India. So I can\'t order it. Is there any other way to update firmware? Through 5350UCM? - slychiu - 02-17-2009 You can upgrade by getting MPU01 which is a plug in module with new firmware see the picture and details here Check with Clipsal if they can order that, otherwise let us know by private message |
