Current Firmware - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +--- Thread: Current Firmware (/thread-2115.html) |
- ident - 09-27-2012 what is the firmware version for the UCM/Zwave? Only Version 6 can be upgraded by Bus - Howser - 09-27-2012 [user=86]ident[/user] wrote: Quote:what is the firmware version for the UCM/Zwave? It is version 6. - ident - 09-27-2012 Sometimes the upgrade may fail You can try again or use the UCM Programing cable - Howser - 09-27-2012 I have tried multiple times, and got the same result. - ident - 09-27-2012
- Howser - 09-27-2012 I tried the programming cable and got the same result. [user=86]ident[/user] wrote: Quote:What was the original UCM/Zwave firmware, Version 6.019 [user=86]ident[/user] wrote: Quote:is the UCM/Zwave still working on its original firmware? After firmware failures, it shows the version as 6.000. It does not work, getting Timeouts and No Response Errors. It did the same thing with version 6.019 hence why I tried upgrading. [user=86]ident[/user] wrote: Quote:Did you try the firmware upgrade by programming cable? Yes - ident - 09-27-2012 Can you show the Monitor I/O display when trying the Programming Cable upgrade please - Howser - 09-27-2012 This is what I had originally... Code: > UB01010EI tried the update again to get the screenshot for you and it went through successfully hock:
- ident - 09-28-2012 I think this could be because of UCM firmware. which version are you using? - Howser - 09-28-2012 UCM as in UsbUcm? UsbUcm is Version 6.008. |
