Dynalite Communications problem - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Lighting Interfaces (https://www.comfortforums.com/forum-39.html) +--- Thread: Dynalite Communications problem (/thread-231.html) Pages:
1
- Scott James - 10-21-2006 When you have the jumper off, it looks exactly the same as the errors I was getting. Hmmmmmmm very interesting!!!! It\'s time I do some more testing!! Thanks for all your help Ian!! Regards, Scott James - NickG - 12-14-2006 Hi I have been setting up a link from Comfort to Dynalite for a customer and have tried both the UCM485 and a UCX/DNG232 approach. Using the UCM485 it works fine but I\'m getting the same error messages on the monitor so thanks for the info about the jumper on G, I note that this is mentioned in the DNG232 article on the Cytech site but not in the manual for the UCM485, so this needs amending. Could not get the DNG232 approach to work at all, D12 was flashing on the the UCX but no message was being received on the network. Questions:
Nick - Guest - 12-14-2006 Hi NickG, Seems like the command works whether the SW8-G is inserted or not, despite the error on the DNG232. As for the 2 queries: 1) Yes you do. 2) This would need to be amended using the DLight2 software |
