Vocabulary Issues - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Vocabulary Issues (https://www.comfortforums.com/forum-76.html) +---- Thread: Vocabulary Issues (/thread-5050.html) Pages:
1
- slychiu - 04-24-2019 I see that you are using ETH02ETH02 fails when trying to upgrade the vocabulary. It was obsoleted about 7 years ago I suggest changing to ETH03 - waynebr - 04-24-2019 So I\'m clear are you saying the eth02 is failing so an eth03 will fix the issue? - waynebr - 04-24-2019 If this is the case I might have to wait till the pi module is released - slychiu - 04-24-2019 No ETH002 is not faulty, but it does not handle the Vocab Upgrade, whereas ETH03 canYou can buy an ETH03 submodule to plug in to the UCM to replace ETH02. - waynebr - 05-11-2019 Hi I have now replaced the Eth02 with a Eth/PI, I\'m still getting vocab errors when trying to upload it. I have attached the log. ***Apologies - Ignore this Matt has just told me that the UCM /PI does not support binary text yet. I will review again when it does *** - slychiu - 05-12-2019 I suggest you send the DSP board to Laser. They have a Voice programmer module that can reprogram the Vocab. If that does not work then that DSP board may be faulty and needs to be replaced - waynebr - 05-12-2019 Thanks I will wait until the new firmware is released for the UCM PI and try that. Otherwise I will need to take the board out and send it off. |
