Vocabulary Issues
I\'m not sure what has happened but during my updates and reprogramming I have lost my Vocabulary, I have tried updating using Myma39 in an attempt to rectify this but I get the beeps on the keypad and then I get a vocab errors message. Can you advise on how I fix this.
And the system info
I assume you have not gone through the Vocab Upgrade YetThe error means that the vocab is incorrect. If you do the vocab Transfer then you will not get the message
Hi the only option I can find is transfer>Vocab Upgrade, This is where I get the error. IS there another way I should be doing this?
That is correct.Can you ignore the error and continue with the vocabulary upgrade
No it looks like it stops at this point, The keypad then starts displaying not polled.
If is normal for the keypad to show not polledThe vocabulary upgrade takes 20  Minutes  You should let it continue in null there is an error messageBut you should upgrade the ucm and comfort firnware beforehand
Hi it dosn\'t look like it will continue, the error message stays up and if I click OK it closes the progress bar. If I ignore it the progress bar stays on 0% and the keypad says no text data - download aborted.
Can you open  the UCM IO Monitor before doing the vocab upgrade, clear the screen, then after the Vocab upgrade attempt, press Copy to Clipboard and show the resultsAlso please check the serial num ber on the Comfort, C or P with 6 digits
HI Below are the results from the IO Monitor.
Serial Numbers:Ultra 2 = P052504, Eth02 = P071567
.pdf   Document1.pdf (Size: 29.76 KB / Downloads: 4)
