WizComfort Keypad - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: WizComfort (https://www.comfortforums.com/forum-21.html) +--- Thread: WizComfort Keypad (/thread-117.html) |
- Patrick - 02-23-2007 I am using same UCM/Ethernet to upload/download. I have only using one UCM in my system. The Comfort and firmware version is in the attached screen capture file - Patrick - 02-23-2007 This is the configuration file from Wizcomfort which also mentioned comfort and firmware version. - BMagalhaes - 04-24-2007 I need to update a CWM via web. As it is required to enter Eng Menu to update CWM I wonder if it\'s possible to activate Eng Menu via Wizcomfort? - Guest - 04-24-2007 Yes you can. Make use of the virtual keypad (F+0), if the shortcut key has not been changed. |
