2nd Generation iPad app Testing - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html) +---- Forum: Comfort iPad App (1st generation) (https://www.comfortforums.com/forum-116.html) +---- Thread: 2nd Generation iPad app Testing (/thread-3878.html) |
- dcrera - 12-04-2014 Hi Thats a good place to start. Will feedback tonite on the results Take care - dcrera - 12-04-2014 Hi Mine is different. Buttons are greyed out Screen dump attached - Ingo - 12-05-2014 Check the firmware version on the Eth03 to be the latest. What you see on the screenshot is old firmware which supports only one port displayed on the new CS Manager software. Oh, and make sure the UCM firmware is > 7.040 (read \'latest\') - slychiu - 12-05-2014 Ingo means upgrade the UCM before upgrading the CSManager otherwise you may not be able to see the ETH03 see issue in http://www.comfortforums.com/forum113/3820.html - dcrera - 12-08-2014 Hi Can I allocate port 1001 to Comfort and 1002 to the Ipad app to avoid the \'busy\' status ? Could this resolve my problem with connectivity ? Regards - slychiu - 12-08-2014 Yes, but for each port, only 1 connection can be made at a time so if you have one device connect to 1001, anoher to 1002, then a 3rd device cannot connect to either port unless one logs out - dcrera - 12-08-2014 Hi Great, that can work for me ![]() Regards |
