Using VeraLite to associate with comfort virtual node - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +--- Thread: Using VeraLite to associate with comfort virtual node (/thread-3993.html) |
- lwillerton - 10-15-2014 Just done a learn from vera in to comfort and uploaded to eprom, no change - leonchue - 10-15-2014 For trouble-shooting, change the virtual node mapping to a counter. Write EEPROM. Read EEPROM to confirm changes. Then trigger VN via Vera/HS again. See if that counter changes state. - lwillerton - 10-15-2014 Nice one...that works I can see the value change from 0 to 255 when the PIR is triggered. - leonchue - 10-15-2014 That is great! We are so close now. Now revert VN mapping back to Virtual Input. Remember to write UCM/Zwave and Comfort. - lwillerton - 10-15-2014 OK done that and back to no status change...I have assigned to input 18 and checked. - leonchue - 10-15-2014 lwillerton wrote: Quote:OK done that and back to no status change...I have assigned to input 18 and checked.Did you program zone type for 18 as well? If it is blank, the zone is ignored and status is not updated. Otherwise, zone 18 operates as what it is, be it security or automation. - lwillerton - 10-15-2014 Hi, It looks like I have removed this setting so will give it a go tonight. Will Zone type Monitor N/C or N/O do? Cheers Lee - leonchue - 10-15-2014 lwillerton wrote: Quote:Hi, It depends on what you want to achieve. Monitor N/C or N/0 triggers FamilyCare alarm in all security modes (by default). So I am not sure if that is really what you want. Maybe you can test with \"SwitchNO\" or \"SwitchNC\" first. ![]() - lwillerton - 10-15-2014 It\'s worked thank you so much...so what do you think caused the problem? - leonchue - 10-16-2014 lwillerton wrote: Quote:It\'s worked thank you so much...so what do you think caused the problem?That\'s great. The problem? Initially, it was the unsuccessful association with VeraLite. After that, the virtual input was not validated in Comfort (without setting zone type). |
