Using VeraLite to associate with comfort virtual node
Hi All,
I am trying to associate an everspring sp103 PIR with a comfort virtual node. My main controller is veralite which can see the virtual node or at leaste something of the same ID (I have called it virtual node by typing in manually) created by comfort, but it can’t populate the information the controller required to complete the setup, therefore vera states “failed at: Getting manufacturer”
Comfort info
z-wave properties
chip version 1
controller type bridge controller
module info 3.52
Has anybody managed to make an association to a virtual node with this config?
If so what is the process?
I have done this in the past with homeseers, aeon labs z-stick 2 and comfort.
Best Regards
Lee
Pic2
Pic3
Pic4
Pic 5
To make the association in vera you go in to the device and setup a group id and the associate another device.
Pic2
If I try this I get a message failed to associate
Pic3
\"but it can’t populate the information the controller required to complete the setup, therefore vera states “failed at: Getting manufacturer”\"
Maybe you should ask VeraLite what this problem is about.
Did you try associating physical devices with PIR also?  Does it work?
What group ID (under Associations section) did you enter for PIR?
