Fibaro Dimmer 2 FGD-212 learned as a Multilevel Sensor - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +--- Thread: Fibaro Dimmer 2 FGD-212 learned as a Multilevel Sensor (/thread-4363.html) |
- MDKKEN - 02-02-2016 Hi, Just to make clear
[indent]However the commands UCM Zwave are the most useful one and therefore usable on or off dimming etc Newer commands in ZWAVEplus will not work [/indent]
- MDKKEN - 02-02-2016 For review of QUBINO dimming module see http://www.vesternet.com/blog/2015/05/awesome-qubino-z-wave-range-stock-at-vesternet/ - slychiu - 02-02-2016 Correct that in most cases Zwave plus devices is not a problem But see the example of Fibaro FGD212 where the dimming commands are encrypted - Guest - 02-03-2016 thanks MDKKEN ... this information too late for me ... just installed 15 Fibaro dimmers + Fibaro controller ( inside comfort network with full 5 Slave Expansion+ LEM ) ... plus UCM zwave for as bridge ... so become useless automation ... This is my mistake choose wrong system - muddymickey - 02-21-2016 I recently purchased a Fibaro FGD-212 dimmer, to start replacing some unreliable X10 micro modules. I can successfully control it via Domoticz running on a Raspberry Pi, using an Aeotec Z-Stick Gen 5 as the primary controller. I also recently purchased a Z-Wave UCM for Comfort and fitted it, as I want to operate my lights based on PIR sensors via Comfort (as I did with X10). I\'ve just updated the main Comfort firmware from 5-something to 7.093. The Z-Wave UCM is running firmware 7.013. I also have a USB UCM running firmware 5.178.Comfigurator reports version 3.10.11.0. Comfort has learned the Z-Wave configuration OK from the primary controller, I can see the Fibaro as a \"Routing_Slave-Power_Switch_Multilevel\" with node type of \"MultiLevel Sensor\". The \"Switch Device On\" and \"Switch Device Off\" buttons in Comfigurator DO work OK. \"Switch Device On\" causes the dimmer to turn on at the last dim level (which was set either via Domoticz or the momentary wall switches). Presumably if Comfort can turn the lights on and off via these buttons in Comfigurator, I should be able to do the same in a response somehow ? However, the only Z-Wave command I can choose in a response is a \"Basic Get Command\". Any suggestions ? - leonchue - 02-22-2016 muddymickey wrote: Quote: However, the only Z-Wave command I can choose in a response is a \"Basic Get Command\".Have you try to click on the \"Basic Get Command\" and reveal a drop-down arrow? Click on the arrow to see \"Basic Set Command\" in the list. See example as attached. - Guest - 02-22-2016 Hi Muddymickey .. its good news for me that you could control FGD 212 from comfort ... have you changed the security association method when connect to aeotec ? - slychiu - 02-22-2016 If your ucm is 5.178 how did you upgrade the comfort firmware to version 7? Did you use the UCM firmware cable? If so you should also upgrade the Zwave firmware to the latest which is more than 7.013 but I do not recall exactly If possible upgrade the UCM 5.178 to version 7 using another UCM so that in future you do not have to use the upgrade cable - muddymickey - 02-22-2016 [user=1]slychiu[/user] wrote: Quote:If your ucm is 5.178 how did you upgrade the comfort firmware to version 7?Yes I had to buy the programming cable. I have two UCMs: Z-Wave (firmware 7.013) USB (firmware 5.178) How do I upgrade my USB UCM ? Also - not sure if this is related or not - but since doing this work yesterday, my keypad is constantly showing \"UCM3 communication failure\". |
