New Comfort2MQTT for Home Assistant - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort with Home Assistant (https://www.comfortforums.com/forum-143.html) +--- Thread: New Comfort2MQTT for Home Assistant (/thread-5511.html) |
- Ingo - 12-15-2024 Those thresholds were hardcoded as I didn\'t have a reference for them. If you can supply me with threshold values you would prefer then I can update the code accordingly. - slychiu - 12-15-2024 Low battery = 11.5V (value = 187) DC Power Fail = 9.6V (value = 116) dont forget to swap around the names of the Charger voltage and Battery voltage Thanks - phil1155 - 12-16-2024 Hello, I have not touch my comfort for a while, using comfort2mqtt (koochyrat) on a debian vm. Installing and playing with HA, I found this post and added on my HA. I can see that bridge and comfort ultra are created, but got an error when starting the add on. HA find the comfort, I see the log but stop with \"list index out of range, halt with exit code 1\". My comfort firmware is 7.142. My battery is currently in error ( low battery\"). I tried to upgrade the firmware with comfigurator over ethernet, but got DUT error. Before I dismount things , may be you could point me to another reason the add on stops. I guess its not because of the battery. Thank you for the addon and your help here - slychiu - 12-16-2024 How did you try to upgrade the comfort? by programming cable or y right lcicking in modules? seee http://www.comfortforums.com/forum4/1783.html copy the Monitor IO when you do this and fails - phil1155 - 12-17-2024 Stupid me, I was using the \"upgrade with cable\" without the cable. Now using the right click on ucm does not work (after F0) and I got this > LI**** < LU01> DT < DT2024121718242100> EL < EL11FFFFFFFFFF> UL000003 < DL00000305FF22D7> V? < V?FE078E22400100> v? < v?05FF27010203FFFF> U? < U?0A076211> SN01 < SN0123010100> u?00 < u?110A076200 < u?1219076A00 < SN11FFFFFFFF < SN12FFFFFFFF < u?3103010400 < SN3100000000 < u?4100000000 < SN4100000000 < u?4200000000 < SN4200000000 < u?FFFFFFFFFF> RD12000002 < RD1200000200FEEE> f?00 > Y? > Z? > z? > M? > K? > a? > d? < NA < f?007DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF < Y?0120 < Z?02C0 < z?000000000000000000000000000000 < M?0001 < KL00020200 < a?070102000100000000 < cc00> LT01 < OK> UB01010A < UBF1> LI < LU00> LI**** < LU01> DT < DT2024121718313400> EL < EL11FFFFFFFFFF> UL000003 < DL00000305FF22D7> V? < V?FE078E22400100> v? < v?05FF27010203FFFF> U? < U?0A076211> f?00 > Y? > Z? > z? > M? > K? > a? > d? < NA < f?007DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF < Y?0120 < Z?02C0 < z?000000000000000000000000000000 < M?0001 < KL00020200 < a?070102000100000000> U? < U?0A076211> LT01 < OK> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5 < SM000000 < DT2024121718330200 < AL0701016C0301 < a?070102000100000000 < KL00020200 < MD0001 < DT2024121718330300 < AL0701016C0301 < a?070102000100000000 < KL00020200 < SM000000 < MD0001 < DT2024121718330800 < AL0701016C0301 < a?070102000100000000 < KL00020200 < SM000000 < SM000000 < SM000000 < SM000140 < SM000000> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5> DAC512531101 < RA0000 < SS190023 < SS19001E> DAC512531100 < RA0000> U? < U?0A076211> LT01 < OK> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5> U? < U?0A076211> LT01 < OK> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5> UB04010A07E1 < UBF5 < LU00 I have a battery warning, would it be the problem? - slychiu - 12-18-2024 \"UBF5\" reply means F0 on the keypad has not been pressed. Dont type F0 in Monitor I/O. Press F and 0 on the keypad before you do the upgrade - Ingo - 12-19-2024 [user=4799]phil1155[/user] wrote: Quote:Hello, I have not touch my comfort for a while, using comfort2mqtt (koochyrat) on a debian vm. Installing and playing with HA, I found this post and added on my HA.Without supplying the full DEBUG output of the AddOn I cannot suggest any course of action. Please provide the AddOn DEBUG output at the time of the failure. - phil1155 - 12-22-2024 Thanks Ingo and Chiu, I reinstall the addon, following Chiu part1 to 5 rcommendations.And updated the firmware, replaced my battery. I finally had the 3 comfort devices. So far so good, the alarm control panel in HA works. But after upgrading again my firmware, and rebooting my HA, I see now just two comfort devices, bridge and ultra. But the alarm control panel still works. The log seems ok, I guess the problem is not because of the cclx file not in ha addon? Many thanks to both . My new problem is phone controler trouble. the phone line has been disconnected 15 years ago and no line in /out plugs any more on comfort. The \"ignore line cut\" is Y. I dont see other point to investigate, by reading the forum. Any suggestion? Thanks - slychiu - 12-23-2024 Whrere do you see the phone trouble alar,, on Comfort Keypad or the Home assistant app? There is no phone trouble alarm AL03.... in the logs so I dont think it is caused by Comfort - slychiu - 12-28-2024 This topic is very long, please continue at http://www.comfortforums.com/forum143/5579.html |
