Fibaro Dimmer 2 FGD-212 learned as a Multilevel Sensor - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +--- Thread: Fibaro Dimmer 2 FGD-212 learned as a Multilevel Sensor (/thread-4363.html) |
- juwi_uk - 02-22-2016 I don\'t think you can do that; ie change a UCM/ZWave to UCM/Gen just by changing the daughter card as the upgrade will prevent you \"upgrading\" from ZWave type to GEN type. - Guest - 02-22-2016 [user=2357]muddymickey[/user] wrote: Quote:[user=5404]bagushandhoko[/user] wrote:Quote:Hi Muddymickey .. its good news for me that you could control FGD 212 from comfort ... have you changed the security association method when connect to aeotec ?Um, no I don\'t think I did - haven\'t changed any security settings on the FGD-212. I just included it as a non-secure device via Domoticz. similar with me ... it just setting for my own house .. IT is my hobby. So the aeotec is the primary control , isnt it ? when include FGD 212 to comfort... it detect from aeotecs or domoticz ? - muddymickey - 02-22-2016 Yes the Aeotec is the primary controller.I added the FGD-212 via Domoticz on the Raspberry Pi. I couldn\'t get it to add for ages, and it turned out that when pressing the light switch 3 times on the FGD-212 to make it available for inclusion, I was pressing the button too quickly. Once I slowed the button presses down, it was included straight away. I think you can include devices direct from the Aeotec Z-stick itself, but haven\'t looked into that. - muddymickey - 02-22-2016 [user=876]juwi_uk[/user] wrote: Quote:I don\'t think you can do that; ie change a UCM/ZWave to UCM/Gen just by changing the daughter card as the upgrade will prevent you \"upgrading\" from ZWave type to GEN type.Ah right, think I understand now. While fitting the UCM/Z-wave, I thought the base PCB looked the same as the base PCB of the UCM/USB, so I assumed they both shared a common base UCM board. Guess not ![]() It\'s quite annoying as I really want to update to latest Z-Wave firmware to see if the Fibaro FGD-212 will work, but it seems I have no way to do it myself. - juwi_uk - 02-22-2016 Hi They are the same hardware but Cytech stop you cross upgrading in the firmware upgrade utility as you can only upgrade like type to same type. Where do you live; county in UK? Ju - muddymickey - 02-22-2016 Live in Derbyshire, work in Cheshire (Stockport). - muddymickey - 02-23-2016 Have been in touch with Laser Business systems (who I bought the programming cable from recently to upgrade the main board). They\'ll update the UCM/USB firmware for me if I post it to them. Once I\'ve got that sorted, and have updated the UCM/Z-Wave to latest firmware, I\'ll see if I get any further with the FGD-212. - muddymickey - 02-26-2016 Right, I\'m back. First a massive thankyou to Laser Business Systems. I posted off my UCM at Wednesday lunchtime, received it back today (Friday) morning. Superfast turnaround, all free of charge. They wouldn\'t even accept my offer to pay the return postage. Service like that deserves mentioning. Anyway, back to Z-Wave and the FGD-212. I\'ve now updated my Z-Wave UCM to firmware 7.072. And using a counter, I can now use a response to set the dimming level of a light using the FGD-212 ! If I set my counter to a value of, say 5 - and click \"execute response\" - lights come on dim. If I set my counter to a value of 99, and click \"execute response\" - lights come on bright. So the FGD-212 can work ![]() However, I have to use a counter. I can\'t use a Z-Wave action, as the only action available to me is a Basic Get command. Have double-checked, no other options are in the drop-down menu. Is this expected ? - juwi_uk - 02-26-2016 Does it show as \"Power_Switch_Multilevel\" when displayed on the ZWave Mapping tab as the older Fibaro dimmers do? - tech07 - 02-27-2016 I am not sure why set is not pssible but Using a counter to set dim level is more useful than fixed action.This means you can change counter value based on different conditions to set the dimming level, and you can use the comfort app to set the dmming level Note that the counter values for dimming Zwave is 0 to 255, not 0 to 99255 is fully on.0 to 254 counter value is converted to 0 to 99 zwave level, and vice versa for status from zwave. This is so that using the Comfort app, the slider using Counter feedback type will work for dimming and status for Zwave the same way as Cbus and KNX, ie full scale is 255 |
