Comfigurator 3 and Wizcomfort
Is there a problem with comfigurator.3 and wizcomfort? i can\'t get it to connect to any panel i have programmed with comfigurator 3 I tryed it with 3 panels no go
did i miss a new release ??
Wizcomfort is independent of Comfigurator. It should work regradless of whether you use Coimfigurator 2 or 3
Just check that the Comms setting is to the correct port
Wizcomfort has not been changed for some time but is due to be upgarded after Comfigurator
I did check all the settings.
i\'ll try again.
The new Wizcomfort 1.9.0 beta version which reads cclx files is now available for testing, see http://www.comfortforums.com/forum21/1662.html
