Temp in celsius
Hi, as i can read from the user\'s manual, the SCS gives the output temp in °F but later, it says
\"In the Home Control Menu, sensor registers may be used as a feedback. To
do so, the feedback type must be set to type 7 (which is sensor register)
and the feedback value set to the register number. (...)
The temperature may also be announced in either °F or °C. The default
setting is in °C.\"
In a response, the temperature is reported in °F (as indicated in the user\'s manual).
Can i have the temperature reported in °C in responses?
This conversion will be available in the next firmware release. Beta firmware Ultra 5.166 is available from
https://www.cytech.biz/Default.aspx?cmd=sQ0OYE9X66w%2b0P%2bAcFsmAI3j73Rwtfrj&fileid=215&dcid=1&pageindex=
There is a new action to announce temperature in degrees C
This does not include the changing of the units in sensor registers but that will be available soon
Great, thks
Is there now an option to have the temperature values in the SCS in Celsius? I\'d be keen to worth throughout in Celsius if possible
No, the value is saved in Fahrenheit still
