Threads: 1
Hi Guys
chip on UCM5.63 chip on Cbus 5.66
I\'m trying to integrate with my cbus system.
I\'ve run comfigurator but when I request system information and enter 1234 sign in code I just get LU00.
Any ideas?
Threads: 885
LU00 means the sign in code you used (1234) is wrong
You need to use the sign in code for Comfort
1234 was the default code when Comfort is shipped from the factory. Have you not changed your sign in code. Your system UCM 5.63 and Cbus 5.66 are about 7 or 8 years old so I hope you have changed the sign in code during that time
Threads: 1
Hi Slychiu
Thanks for your reply
I see the problem now.
The system was installed by my father who died last year and I\'ve moved into the house with my family I don\'t think he ever got around to finishing the install I guess he changed the code but I don\'t know what code he used.
I also don\'t have any of the manuals for the system it\'s a 5300 Series Clipsal Controler. Model 5300TCU8/8
Is there a way of reseting back to factory defaults?
Paul
Threads: 1
Slychiu
Many thanks for the info.
Threads: 1
Hi Slychiu
I tried over the weekend with no luck it looks like my dad changed the engineer code.
What are my options?
Threads: 885
You can buy a U4 EEPROM for FS24 with default configuration which means the code will be 1234. However that means that your programming will have to be redone.
send an email to support@cytech.biz
Threads: 1
Slychiu
Thanks I\'m not worried about the programing I don\'t think my father did very much as he didn\'t get it finished before he became ill.
There are still sensors which have not been connected so it\'s a bit like a complete new install for me.
I was going to rip it all out and just get a standard alarm and leave the cbus lighting separate.
It\'s unfortunate he didn\'t leave the paperwork and I\'ve ended up with this problem.
I\'m away for a month for work I\'ll get back to you when I return.
Many thanks
