Comfigurator for KT03
Comfigurator 3.2.4 is the recommended version to support KT03 programming, see http://www.comfortforums.com/view_topic.php?id=2030&forum_id=20&jump_to=8220#p8220
However there is an issue when using Windows 7 or Vista;
In KT03 Comfigurator,  clicking on KT03 Pages may cause exception when using Windows 7 or Vista.
Also Write to KT03 may not work, causing KT03 to REST instead
The Workaround is to run Comfigurator with Administrator privileges
If you have a UCM/USB for programming Comfort, please note there will be 2 USB interfaces (and serial numbers) detected by Comfigurator.
[color=\"#ff0000\"]Make sure you select the KT03 USB Interface when you write to KT03 and the UCM USB Interface when you write to Comfort and do not mix up the two[/color]
