07-02-2011, 01:10 AM
Hi is there any way to adjust the brightness on the KT03 my screen seems to be quite faded.
KT03 Screen brightness
07-02-2011, 01:50 AM
There is no adjustment to the contrast
However the contrast may be better when you invert the screen 180 degrees We have an led icon overlay which suits that orientation Are you able to change the orientation?
I have loaded the kt03Template over the stock template and things seem to be a bit better deeper blacks etc.
Unfortunately I cant rotate the screen as the touch panel gets moved further away from the door making it harder to see. I was expecting the screen to be the same as on the marketing images (white background & black text) but I suppose itââ¬â¢s just a case of getting used to standing directly in front of it at eye level. |
« Next Oldest | Next Newest »
