I have a Comfort II Ultra system.
I have an outputs on an LEM (8 input /8 output) connected to the main motherboard. I use this output for lighting control by pulsing a relay (TWS).
This outputs don\'t work.
I measured the voltage between the common centre terminall of the terminal block (which is at 12V) and the output itself, then I see 0V when the output is ON and 0V when the output is off.
Any assistance you could provide in assisting me to resolve this issue would be appreciated.
